is250 front brake upgrade
Old 12-29-17, 10:13 AM
Carolo4554
Carolo4554's Avatar
Default is250 front brake upgrade
can i use the front brakes from a Rc200t on a 2007 is250?
Old 01-26-18, 02:01 PM
timmy0tool
timmy0tool's Avatar
i am unsure myself but there is only one way to find out!
you will need the calipers and rotors. see if the rotors mount over the hubs first then see if the calipers bolt onto the knuckle and it all lines up. if it does then you can run the brake lines afterward.
I've always wanted to do this, as I have access to some GS430 brakes.
Old 01-26-18, 07:00 PM
Aspect
Aspect's Avatar
Doing a bit of quick research, the front rotor is 13.1 in diameter, same as the IS350 brake rotor, so it would be do-able after modifying or removing the dust shield. On that same note, why not get IS350 front brakes? They are 4 piston calipers versus the 2 piston calipers on the RC200t and prob cheaper as well.
Old 01-26-18, 11:14 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
The RC200t uses the same brake calipers and rotors as the IS350 (they're both 4-piston). They will fit fine with the exception of the backing plates. You'll need to modify yours or (preferably) get IS backing plates.
Jeff
Old 06-07-18, 03:23 AM
samsonn25
samsonn25's Avatar
Not to beat an old horse dead.
But cross drilled rotors are still used in many racing applications because of its benefits.
As far as longevity its obvious that drilled holes weaken the rotor integrity. Serious racers dont car because they can change out rotors and pads after every race. Just like how Top Fuel drag racers rebuild engines after every run.
For street driving drilled rotors will last a long time. Assuming quality materials and assembly.
For track days and racing there are many stories of Porsche and Ferraris with Brrembo brakes that torched their plain flat rotors and or cracked their drilled rotors on day 1 or day 2. Real race spec calipers and rotors are different than the ones they put on street carse
Old 06-09-18, 11:11 AM
2013FSport
2013FSport's Avatar
Received 1,513 Likes on 1,258 Posts
FWIW.... there are sites that offer a Where Used capability. Unfortunately if I type it in "HERE" it turns to *********.....
Which makes no since as they don't even sell parts. The name has toyota and DIY in it...
It is a great tool though as see where components are used.
Old 06-14-20, 01:35 AM
Jim250
Jim250's Avatar
Default Upgrading is250 front brakes to is350
Hi i am doing an is350 brake calipers and discs upgrade on my 2007 rwd and I have a problem my 18inc wheels won't fit and I dont really want to use spacers any solution's 🤔
Old 06-14-20, 10:37 AM
primavera
primavera's Avatar
Old 06-15-20, 08:38 AM
Patton6964
Patton6964's Avatar
please don't shave your calipers....
Old 06-25-20, 07:06 PM
06is250jo
06is250jo's Avatar
I did a is350 big brake swap to my is 250 ...
I found a wrecked is350,I took the calipers, rotors and dust shield for 70.00 bucks.it was a bolt on..felt the difference right away.
also painted them red with decals.
memoalkati
Suspension and Brakes
10-10-17 07:57 PM
xdafru
04-17-14 01:40 PM
stlgrym3
19
03-02-12 10:20 PM
neocyclist
10-27-10 12:24 PM
ilv1004s
14
10-05-08 04:49 PM
Quick Reply: is250 front brake upgrade
