squeaking noise from brakes
I am getting this loud sqealing noise from my brakes every time I go in reverse.
It also happen for the first few seconds when I go forward until I tap the brakes once or twice.
It seems as if something is sticking and not releasing the brake pads all the way back.
Any suggestions?
Any suggestions?
- What kind of pads are your running?
- How many miles on them, the pads?
- Is is all brakes, or just one on front or rear? It might be a wear indicator, or a sticky parking brake. Look to be sure so you don't screw up your rotor.
HTH
HTH
I am using the oem pads and they have about 20k on them.
It seems to be coming from the rear wheels only and my rotors look ok.
If i creep at about 5 mph it squeals and if I tap the brakes it stops making noise. Is there something that needs to be lubricated?
Messy-
I had the exact same problem. I even put new pads all the way around. Same squeakiness. I ended up putting a new shim kit on the front brakes. Problem solved!!!
Matt
Matt
