Vibration
Vibration
I just got done getting my alternator replaced at a local dealership and it's raining cats and dogs on the way back to work. Recently I put on a set of L-Sportline Model 4's and I know they were "road-forced" balanced on a Hunter machine and didn't have any problems whatsoever before the work I had done today. I'm doing 60 and all of the sudden my steering wheel almost shakes itself loose from my grasp. I pull over thinking I'[m about to loose a wheel and check the lugs. Everything looks cool, also It doesn't look like I threw any weights. I get back on the beltway and no more vibration....hmmm this is getting very weird. About a 4 more miles I get the vibration again !! Thinking this time maybe my rotors are warping, so I apply some brakes and NO vibration...Rotors ok...
What do you think ? Shocks/struts going out ?
01 GS430 with 30k miles...
Jim
Jim
This has not happened since It was raining. One thing I noticed the other day when I was washing the GS is that the wheels do carry a tremedous amount of water, could this be the problem ? Could the fact that the water being inside the wheel during a downpour cause a balance problem ??
Would that be something to think about ?
Jim
Jim
Yes, the wheels carrying water is the problem. Happens with my HRE's also. In dry weather, perfectly smooth ride, and most times in rain no problems, but once in a while, water seems to get trapped in the inner rim I'd guess and it acts like an irregular weight causing vibration / wheel shimmy. If it's real bad I slow down, let the water fall out of the rim and then start up again.
Thanks Bit for the reply...
I knew I wasn't going crazy here posting that response..But that was the ONLY thing I could come up with.
I'm running SO3's 245/40-19's and 275/35-19's, they are THE best according to wet traction....but be careful when your running wide wheels in the rain !!!
Jim
Jim
