Prothane Poly bushings in Toyolex Frnt LCA
'93 SC-400
Has anyone SUCCESSFULLY installed Prothane Poly bushings in the aftermarket Toyolex Lower Control Arms?
MY OEM ball joints in the OEM LCA's are shot so I picked up a set of Toyolex replacement LCA's with their standard rubber bushings already installed.
I'd like to replace the Toyolex rubber bushings with a set of Prothane Poly Bushings that I'm positive fit the OEM arms because I already did that swap once before.
(Yea, I already know that voids any warranty but I like Poly bushings).
Before drilling & burning out the rubber bushings in the Toyolex LCA's, I measured the Toyolex "Barrel" ID to be sure the Prothane poly bushings will fit.
However, it appears that both bushing barrels on the Toyolex LCA's are about 1.5 mm LARGER than the respective Prothane bushings AND the OEM LCA's.
Note that I AM aware the two LCA barrels on the front lower arms are different ID's. BOTH are about 1.5 mm larger than the respective Prothane bushings and OEM arm barrels..
Therefore, it appears that both bushings would literally "fall into" the barrel of the LCA's and never fit snugly. With that much slop, they would get torn up within minutes of driving.
Before I give up, leave the rubber bushings in place on the Toyolex LCA's and live without my poly bushings, has anyone already been down this road?
markdav801
01-17-18 10:56 AM
Ahheck01
Suspension and Brakes
01-12-15 06:27 PM
SuperCoupe400
06-02-07 06:42 AM
