friction noise from front brakes
Old 08-01-18, 04:23 PM
flowrider
flowrider's Avatar
Received 1,937 Likes on 1,365 Posts
Originally Posted by RisingStar
my mechanic just put the pads.
what is the bed-in process looks like?
the rotors are oem new , replaced the old ones because of this noise.
https://www.zeckhausen.com/catalog/i...Path=6446_6443
Lou
Old 08-07-18, 12:56 AM
RisingStar
RisingStar's Avatar
Tomorrow I am going to my mechanic to try to solving this problem, this the things that I am going to inspect, any more ideas will be great.
1. seized caliper
2. Dust shield (backing plate) touching the rotor.
3. the back drums "eats" the rotor (https://www.clublexus.com/forums/sus...ml#post1831760).
any more ideas?
Thanks alot
Old 09-06-18, 05:25 PM
tbarrios
tbarrios's Avatar
i hear squeaks when driving from the two front brakes. The pads look thick. I took my car to a mechanic and he said the previous brake job was a pad slap and that i need new rotors and pads on the front wheels.
Old 09-06-18, 06:52 PM
flowrider
flowrider's Avatar
^^^^He's FOS. Do a search to see why.
Lou
Old 09-06-18, 07:11 PM
tbarrios
tbarrios's Avatar
Google says I need anti-rattle clips and silicone rubber insulation parts needed to dampen the noise
Old 09-06-18, 08:48 PM
flowrider
flowrider's Avatar
^^^^Are your brakes rattling or do they squeak? Have you tried bedding them in per chance?
Lou
Old 09-06-18, 10:35 PM
tbarrios
tbarrios's Avatar
Once they are hot they squeak when I break and rattle when I drive slowly without engaging them.
tbarrios
tbarrios's Avatar
I haven’t tried bedding them—just bought the car.
Old 10-16-18, 10:07 PM
Israelq95
Israelq95's Avatar
1. seized caliper
any more ideas?
Thanks alot
Did you ever find the solution to this? Mine are doing the same thing. All OEM plus the hardware.
Old 01-29-19, 02:52 PM
RisingStar
RisingStar's Avatar
tomorrow I am going to the authorized garage, and I hope they will fix my problem .
I will update if they find anything
Old 02-15-19, 03:56 PM
KonaRX
KonaRX's Avatar
I had some odd noise/vibration from my 2011 with 14k miles when I did mid speed braking.. I pulled the calipers and checked the caliper pins. The right side lower one was stuck. I used 3M Silicon lube on both after I cleaned them. Also pulled the pads and clips. Cleaned the clips and the ends of the pads where they contact the clips. Used some high temp brake grease (sparingly) and put things back together. Did the other side and found the lower caliper pin was barely moving so did that side too.
So the issue is that the pads were hitting the rotors at an angle since one of the pins was “frozen” preventing the caliper from pressing them into the rotor evenly.
New pads and rotors won’t perform as they should if your mechanic doesn’t service the associated parts. Not sure if that’s your issue, but hopefully this helps.
alaskaty
RX - 1st Gen (1999-2003)
22
10-16-15 10:10 PM
xMJx
11-24-13 09:35 AM
liquidx
Suspension and Brakes
09-09-10 05:56 AM
Farino81
05-10-09 10:09 PM
Quick Reply: friction noise from front brakes
