Anyone replaced their own shocks?
Old 07-17-03 | 10:17 PM
buuzy's Avatar
buuzy
Question Anyone replaced their own shocks?
My Tokico's are on their way. Since I've read that the rears are easier to replace than the front I plan on replacing the rear ones myself and have a shop put on the front ones at a later date when I have the extra cash. Is this a good idea? I would rate myself as an average mechanic.
Old 07-18-03 | 06:09 AM
Keith13b's Avatar
Keith13b
Thats funny, as the fronts went on very easy for me, and it was the rears that took forever.
If you can do one set.....just do them all. Its not that hard! Just rent the spring compressor, as most places nowadays rent free tools w/ a deposit.
Old 07-19-03 | 10:41 AM
sc400's Avatar
sc400
I have the 96 SC400. The rears are so easy; I replaced them in half-an hour both. The fronts I had to give up and took the car to the shop
Old 08-11-03 | 06:56 PM
Carbon J's Avatar
Carbon J
Default Shock install
SC400 can you tell me where you had your shocks/springs installed? I to live in the Bay Area, near Richmond. Any advice would help thank you.
Ajay
Old 08-12-03 | 10:00 PM
SC2jz's Avatar
SC2jz
I pulled mine out and replaced them with my tein ha's. I though it went pretty smooth without a spring compressor. The driver side front is a little more of pain because you have to move the window washer reservoir, in order to get that long bolt out.
Old 08-13-03 | 05:56 AM
Keith13b's Avatar
Keith13b
What long bolt?
Old 08-13-03 | 01:01 PM
808state's Avatar
808state
Originally posted by Keith13b
What long bolt?
probably upper control arm bolt. i also had to remove the window washer reservoir to get that bolt out. i believe it tells you to do this according to the manual. though i'm sure there are ways around this.
Old 08-20-03 | 05:54 PM
sc400's Avatar
sc400
Default Re: Shock install
Ajay
Ajay,
I had mine done at this shop in Milpitas, CA but since I wouldn't recommend it so I'm not going to name it here. Still searching for a competent and honest mechanic after 20 years of driving
Vibes63
Suspension and Brakes
16
07-18-12 02:58 PM
RUBZERK
04-21-12 08:37 AM
biodev
10-23-10 07:44 AM
SLEXC400
Maintenance
04-15-08 06:24 PM
jag_600
Maintenance
06-17-04 02:08 PM
