Brake Fluid Tester reading 3% Moisture
I had my brake fluid changed just in March this year. After a canyon run, I apparently boiled this to the point where my brake fluid tester is reading 3% water content. Not gonna sugar coat it, I spent a hard 20-30 mins doing a spirited run with an M3. Should I replace my brake fluid this early on? From now since March, I’ve only added 3,400 miles to the car. Most likely would replace the fluid with Motul RBF600. Current brake fluid is just the Toyota Brand.
Not even sure if this is still relavent to you, but it couldnt hurt to replace it. not sure on how necessary it is, but it couldnt hurt.
ToyotaLexus
Suspension and Brakes
02-16-09 07:46 PM
