APEXi World Sport Coilovers - Thoughts n' Feelings
I just ordered a set of APEXi World sport coilovers for my 02 GS300... Ive read reviews about them saying that they are very soft and stock-like drive. This is something that I prefer since I dont race around my GS and I mainly cruise it.
I wanted to get some feed back from other CL users about these coilovers... Pro's and Cons would be great..
Also any install stories.. from the looks of them, they just go in like any other coilovers, but you have to use the stock upper mount (shouldnt be an issue)
Thanks for all the feedback in advance...
I have Apexi WS Coilovers. Installed them about 6 months ago. They give a better than stock handling, but are still very comfortable. In terms of hardness, well, they are soft. Very close to stock.
Initially, after the install I still had my 17" stock rims, at that time I felt that the Apexi were a bit too soft. However, after getting 18" and pumping up my tires a bit, I think they are quite nice.
The good thing was that they were very cheap. I live in Hong Kong and got them for USD800 including installation
Alex
Alex
i had h&r springs before the coilovers and the acura rode like *****... after i got the apexi's i slammed it to the ground and it rode nice. i'm sure it will be the same for the gs. i'm gonna go ahead and order them. let me know if you get em cheaper than autocarparts.com. has them for.
take care...
take care...
I really liked the hieght adjustment on them too. I believe you could go as low at 4 inches. The only downside is that I wish you could adjust the stiffness on them also.
Another quesiton I had.. here it goes...
Right now im running H&R spring w/ stock shocks (yes I know this setup isnt good) .. anyways.. when I have 4 people in the car (average height / weight) and a full tank of gas the rear has no gap when it normally has about 1-1 1/2 finger gap..
WHen I get these coilovers installed Im going to adjust the rear to have no gap, or even have the tire tucked in the fender...
now my question is this... will I have to worry about the wheel going to far into the fender when I have people in the rear, or since these will be a good set of coilovers + much better setup that Im running now.. I wont have this problem..
Or, do I need to get replacement springs from Apexi to have a stiffer setup in the rear?
Thanks!
Thanks!
Thanks!
Thanks!
I used to have my set of Apexi WS a bit lower than now and when I was driving the car with only one person (myself) there were no problems. However, when I started to drive my family around, I found out that the persons in the back were not enjoying the bumps in the road and they were shaken a lot.
Therefore, I had to readjust the height again.
So, if you have passengers in the back, you cannot go too low
