DIY Coilovers Install
No, but make sure you have your sway bar end links tightened all the way down and go over the rest of your bolts. You may just have bad endlinks or some other component. Check your ball joints etc.
Scorp79 (04-17-19)
yooo, I had found that the noise was coming from the left rear end link, it wasn't bolted in.. the bolt missed it completely and the end link was stuck in the lower control arm
![Rock On](https://www.clublexus.com/forums/images/smilies/rockon.gif)
Did you have any issues getting it aligned bud? Thanks in advance
Wow. Looks so much better. Amazing how just a little difference in height can change the look of a car. Love seeing people working on their own cars, so much more gratifying and fairly simple. Great job. Looks killer!
How did you assemble the actual coil over itself? I’m having so much trouble with the assembly. The top hat doesn’t sit correctly on mine for whatever reason.
