Steering wheel shake over 65mph
Hello, i have a 98' gs300 that im building for street/track some drifting time attack autocross whtever comes on the way,
I have done:
Ksport coilovers
New front sway bar end links
Superpro(Figs) Sway bars front and rear
Superpro(Figs) Lower caster arm bushings Poly
OEM Upper control arms
Tie rods inner and outter were replaced not long ago with Acdelco pro-line
Lower control arm Poly Bush Siberian Bushings
Whitline steering rack Poly bushes
Moog new ball joints
Cusco Strut Bar
Endless SSY pads
Brembo Xtra performance Rotors
Did not re-align after upper arms but did balance wheels and car still shaking steering wheel and small front end vibrations, i did order 30mm Roll center adjusters, car was aligned half year ago and its 2+- inch lowered. Thanks
I have done:
Ksport coilovers
Cusco Strut Bar
Endless SSY pads
I doubt my whitline bushes because they were a bit bigger than old bushes and i did cut some of the poly on main big bush and it did fit tight, but idk
YES i did try searching and so much times, if you look up i described all mods very good because when i search they ask him to check many things so i figured out that i should mention all my suspension works so people help can be more accurate also most people who post do not list any where close to the work i did so they multiple things to check. next time keep that unhelpful comment for yourself. thanks
This guy and that SaiyanGS guy live to post rude comments. Never help with anything, don't pay attention to them or waste time responding. His link doesn't even lead to anything. Nice
My question to you is, have you been replacing parts to chase this issue, or has it come after you've started making changes? If the later, you will need to go over your work and double check settings, bolts for tightness, etc. What wheels and tires are you running? using spacers? offsets normal or far from oem?
Hi, thanks for replying.
Im just building the car but as i did all those changes i always thought im getting rid of steering shakes and small bumpsteer. my goal actually is to make car handle and performance better but as i did all that also there must be no steering shakes, i agree with vibrations because very stiff setup all poly bushes thick and supper stiff bars and coilovers but my problem is the steering wheel shake. Tires are Toyo t1sport proxes on all wheels, i run stock wheels with no spacers. also as i remmember -1 camber front and caster was close to equal
Are you doing the balance yourself or having a shop do it? Some inexperienced techs just do a static balance on everything and call it good. The car will feel like garbage and they wont know or care because they never test drive up to speeds over 45. Some will also not mention that a wheel is bent or damaged and taking a lot of weight. Its just a get it in and get it out of their hair kind of attitude. Id try the same shop and mention that you think there's a problem with the balance and have it checked again. Balancing is done by lower level mechanics in shops. Or try another shop and ask to know how far out they are before removing weights.
Thanks for trying to help, but my friend is only tires/wheel shop already years and he balanced it so accuarte, i dont think its wheels at all no bends and did balance everywheel on the car, i think its just because car is lowered or becuase i did cut steering rack big bush but it was tight. my RCA on the way will bolt them up and see what happens, also i have bad rack it leaks but it works okay maybe its the problem too, but as i asked many pro mechanics they told me rack never makes the car shaking or steering wheel its only going to be hard and have numb spot which its not happening with me soon i will lift the car and check everything again when i install the 30mm rca. thanks again
Have you replaced your front lower caster arm bushings? Some people have said that the rubber wears out and causes that shake. FIGs sells a press in replacement
https://www.shopfigs.com/v3/by-vehic...ADJCST2-40-SPF
Here's a fishing rod.
Regarding the search on this site. Its absolutely terrible and doesn't help at all. Go to google and type your search keywords followed by "site:www.clublexus.com" that will only give your results from this site and its a lot easier to find what you need on google than here. That will hopefully help you find what you need in the future
Hi, i actually have super pro sways thick bars and 175% stiffer front and 200-235% stiffer rear adjustable Thanks for info i will try to change pre load
I have found after 12 years of owning a 98 GS400 that wheel lug nut torque is crucial to having a vibration free car. Many shops only check for minimum torque, meaning they impact them down to full pressure and run a torque wrench on them to be sure they are at least at the factory setting. Ever notice they never have to add torque to a lug? For that matter, ever had a shop ask you what the torque should be set to? When I do mine I tighten them down to within 10% of factory set then hand torque them the rest of the way. It is just as bad to over-torque as it is to under-torque lug nuts.
Torque values are set for a reason.
Tony55330
Suspension and Brakes
01-20-23 05:41 PM
irokdastar
08-08-11 09:44 PM
