Adding New Springs -- Alignment Needed?
Old 08-05-03, 06:32 PM
BuyERTS
BuyERTS's Avatar
Default Adding New Springs -- Alignment Needed?
As my first mod, I'll probably be getting the L-Tuned springs added to my currently stock SportDesign. Is a wheel alignment in order when something like this is changed? What other suspension changes (besides springs and shocks) might warrant an alignment?
Old 08-05-03, 09:51 PM
GS4Will
GS4Will's Avatar
of course...
Old 08-06-03, 12:43 AM
PHML
Master Thread Closer!!
PHML's Avatar
Its NOT if you need it....Its how quick can I get it done....preferably right (same day) after the new suspension installation.
Old 08-06-03, 05:19 AM
wineohs
wineohs's Avatar
Uh Oh,
Had my L-tuned shocks and springs installed about 2 months ago and asked mechanic (NOT DEALER) to give it a 4 wheel alignment. He said that it didn't need one. I assume he checked..Car doesn't pull to either side or anything...Could it be possible that it didn't need an alignement after the L-Tuned installation? I also put on new rims and tires right after L-tuned and don't want to eat through them.
Old 08-06-03, 09:10 AM
BLiu
BLiu's Avatar
You may want to wait about a week before doing the alignment. That will give time for the springs to settle because it will change a bit from day 1 versus day 7...
Brent
Old 08-08-03, 10:35 PM
jmecbr900
jmecbr900's Avatar
You WILL need an alignment.
Old 08-09-03, 01:42 PM
Received 2,428 Likes on 1,591 Posts
Default Re: Adding New Springs -- Alignment Needed?
If you have SportDesign, I thought it had equivalent of L-Tuned setup? Was wondering why you're doing springs and not shocks at the same time?
Old 08-09-03, 02:44 PM
FutureGSorIS
FutureGSorIS's Avatar
Default Re: Re: Adding New Springs -- Alignment Needed?
The SD only has the ltuned shocks but stock springs so he is just completing the setup with the ltuned springs.
Old 08-21-03, 08:45 AM
sung35
sung35's Avatar
I remember from some post that if L-tuned shocks are used on stock springs, the new shocks will be ruined in a few months. If so then why Lexus has SD in such a combo. I think SD has L-tuned shocks and L-tuned springs. I might be wrong because I don't have an SD
wineohs
Suspension and Brakes
08-16-03 11:35 AM
888GS430
01-25-02 05:49 AM
RealMarty
09-02-01 12:41 PM
gwu128
08-09-01 09:44 PM
gmendoza
03-17-01 07:12 AM
Quick Reply: Adding New Springs -- Alignment Needed?
