Akebono Brake Pads 2017 IS F sport
Old 03-25-19 | 05:32 AM
simon876's Avatar
simon876
Exclamation Akebono Brake Pads 2017 IS F sport
Hey guys, its about that time to change my pads. I've been looking at the forums and have decided to go with the Akebono pads. Can anyone tell me the 'ACT 1118' can my 2017 lexus is 200t Fsport model?
Old 03-25-19 | 05:39 AM
Flash5's Avatar
Flash5
I recommend the ASP 1118's as they are a little sportier than the ACT's. But if you insist on the ACT's, then yes ACT 1118's are the front pads.
simon876 (03-26-19)
Old 03-25-19 | 06:38 AM
Burrcold's Avatar
Burrcold
Both are great. You are going to get slightly more dust with the ASP's vs the ACT pads, but you also get ever so slightly improved braking (the difference in dust or braking performance is negligible to be honest...I had the the ACT for about 3,000 miles and now the ASP pads for close to the same). In hindsight I should have kept the ACT pads since the difference is so little.
simon876 (03-26-19)
Old 03-26-19 | 12:22 AM
simon876's Avatar
simon876
Thanks for the speedy response!
Old 03-29-19 | 10:09 AM
NickCaesar's Avatar
NickCaesar
i just bought the ASP’s, Installing Monday... I’ve read a lot of people complaining about squeaking even after thousands of miles, have you experienced any noise?
Old 03-29-19 | 10:54 AM
Burrcold's Avatar
Burrcold
Both the ACT and ASP pads have squealed but only when it's cold or wet, and only for the first few pushes on the brakes (and strangely almost always only when reversing).
Old 03-29-19 | 12:25 PM
Flash5's Avatar
Flash5
I’ve had 0 squeals after 10k miles on the ASPs, but that might be because I use copper antiseize on the back of the pads and the places where there is movement.
Old 03-29-19 | 03:41 PM
NickCaesar's Avatar
NickCaesar
did u do any break in procedure? Like multiple stops when u first installed them
Old 03-29-19 | 05:17 PM
TOPENDMS's Avatar
TOPENDMS
Former Sponsor
Never hurts to review the manufacturers website ..
Pro Act:
https://akebonobrakes.com/pro-act
Performance
https://akebonobrakes.com/performance
Unless your building for speed, i’de probably go with Pro Act
Old 03-30-19 | 06:45 AM
Flash5's Avatar
Flash5
No, Akebono just recommends that you not stop hard for a few hundred miles I believe. Check their website I can’t remember. Lol
Old 03-30-19 | 08:18 AM
AtomicAWD's Avatar
AtomicAWD
Oh well, I followed R1's recommendation for their rotors and did the break-in.
Old 04-01-19 | 08:21 PM
simon876's Avatar
simon876
What slotted rotors you guys suggest with these brake pads?
Old 04-01-19 | 09:16 PM
AtomicAWD's Avatar
AtomicAWD
I just went with regular ones. Slotted may be better for off-road and track, drilled may be better for wet, maybe for cooling, but then you lose some surface area, they probably can't be turned, and they likely wear pads out faster. Didn't really see the value in paying extra for it.
Old 04-14-19 | 05:17 PM
simon876's Avatar
simon876
SO the Akebono ACT work great, had no squeals, definitely less dust!!! (that's what i hoping for). For the F Sport, they are just about as equal in braking performance, i might give the FSport a slight edge over breaking if you decide to speed a couple of times up & down the road. But I am pleased with it none the less
TOPENDMS (04-14-19)
Old 04-14-19 | 05:26 PM
Burrcold's Avatar
Burrcold
Good choice!
simon876 (04-14-19)
