This forum is a bit slow... I'm gonna show off my new toys
Birthday, Graduation, and Christmas presents.
FIGS Mega Arms, Figs toe control arms, Fortune Auto 500 coils, and an IS F Steering ECU:
Also note, new OEM hardware from Lexus for pretty much everything. I'm only fighting with the 11 year old nuts 'n' bolts for long enough to get them off!
I'm a bit excited, but it will likely be June before this all goes in (I'm pretty much full time soccer dad until then). The coilovers have standard 12kg/8kg springs, I figured I'd try them out and see how they feel. I'm way too old to be a super frush, slammed flat billing hipster, I want the car to handle, but I also prefer my spine in one piece, and my fillings securely in my teeth where they belong. If I make it to the track once a year, its a good summer. If necessary I'll upgrade to 13kg/9kg Swift springs next summer.
Looks like you’re off to a good start. Pair that with some sway bars and you’ll really be handling like a boss. And kudos to you for buying quality parts.
Speaking of spine and fillings - those heim-joints won't offer much damping so I wish you luck there.
In your quest to make it drive better you might want to grab the LCA while you're at it. RC-350 are firmer than IS-F which is firmer than our ISx50 or go for urethane FIGS option.
Anyone have input on how long those exposed heim-joints last and/or have a supplier for replacement?
kenji211 (06-17-19)
Here is what FIGS says about the rod-ends:
Originally Posted by FIGS
2-piece Motorsports: FIGS FXM MOTOrsports rod ends for daily driven applications. These rod ends provide the high shock load resistance for the daily riggors of unmaintained roads, potholes etc. Injection molded Teflon composite race and Chromoly construction.
If only I could justify a OS-Giken.
Hey , just checking in on your progress. I’m looking to buy coils this month and I was set on BC but I don’t know how I feel about the minimum 2” drop. I feel that’s a little too low for me. I hear the Fortune is a minimum 1” drop from a friend who used to work there which leaves me plenty of room to fine tune the set up to suit my needs. How do you like your setup?
I am interested to hear about the Fortunes with the digressive valving and how that feels, I heard it provides more road feedback which may be better for
the track, but I'm worried that would be a harsher ride on the street.
bbaugher47 (06-07-19)
I'm not terribly concerned about the heim joints. The sub-frame bushings on these cars are pretty soft, which isolates any harshness in the actual suspension arms. I've had cheap arms (Megan) with heim joints in the car for several years, and they didn't make a noticeable difference in harshness. I think I've had the FIGS front lower control arm bushings in the car for almost four years now, they were worth every penny and didn't add any harshness.
We can always dream... you know what'll happen eventually, though
EDIT: it's a gs450h, but the platforms are pretty much the same.
I had BC coils on my is350 and I could set them as high as stock height, maybe higher I never tried, I had them at about -1.5 inch front and -1 inch rear... I am interested
to hear about the Fortunes with the digressive valving and how that feels, I heard it provides more road feedback which may be better for the track, but I'm worried that
bbaugher47 (06-10-19)
mike33 (06-10-19)
Thanks for the link, it provided some good info. I will be in the market for a set of coilovers for my isf soon, so I will be interested
in any feedback you will have. It will be interesting to see if they provide the ''supple compliant'' ride as well as increased
''mechanical grip'' they tout with the flow digressive technology.
Interim update for now...
I got all of the suspension components installed over the weekend and got the car aligned.
The install was an adventure, bolts that were installed in the factory 11 years ago can be a bit difficult to remove sometimes. Not pictured in the original post, I also have FIGS front and rear swaybar end-links which I attempted to install. The front went just fine, the rear not so much. The old end-links simply refused to give up their place, so for now I just removed the rear swaybar. I'll probably get it back in this weekend, after I go medieval on the old end-links.
With everything else in place I lowered the car 1.25" on all 4 corners. Conservative lowering, I know, but my ultimate goal is 1.5" lower, if these "settle" as I hear some coilovers are prone to do, I didn't want it to end up closer to 2" lower.
I chose a shop that is ~20 miles from my home for the alignment, they build racecars and sell exotics. I'm tired of taking the car to local shops and getting when I tell them what I want. I'm running basically the same alignment I've used for the last ~5 years on this car. 2* camber, 1.5mm toe-out on the front, 1* camber and 0 toe on the rear.
The drive to the shop was predictably nerve-racking. Having just loosened and torqued every bolt under the car, installed a bunch of new hardware, and then not having enough time for even a rudimentary alignment, it was white knuckle driving at its best. I eventually made it, and the shop was quite a bit of fun. I told the tech my specs, they didn't bat an eye and threw the car on their rack next to an Audi R8. Here is part of their showroom:
The Huracan on the left has been their flagship (I think... there has also been a glorious sounding LFA, but that may not belong to the shop) track/race car. Its absolutely nuts. All carbon wide body that has been used and abused, and is proud of the frayed edges and battle damage.
But I digress.. Alignment went fine, all the specs turned out exactly as I wanted. I don't have pics of the car, but seriously, its an old tree-fiddy with a ~1" drop. Its not going to set the internets on fire.
Look, all two of y'all thought I forgot ride impressions!
Really I don't have much yet. On the first drive to get an alignment I left both front and rear dampers at full soft. Between that and the rear toe settings being WAAY off I didn't like it. It was too soft, and too soft with horrible toe settings mean the car wants to change lanes when you hit a bump and the rear suspension travels more than an inch.
After the alignment I put 6 clicks in the front and 4 in the rear (shocks have 24 total clicks) and it drove MUCH better. Subjectively it feels just a hair stiffer than stock, but subjectively it seems to corner a bit more flat, and remember this is without a rear swaybar!
Over the next few weeks I'll play around with the clickies a lot more and get the swaybar back in, then I'll see how I really feel about it. So far I'm pretty happy. It still rides nice so my wife won't be upset, and I think it has to potential to handle quite a bit better when I want it to.
Next step (after getting the swaybar in), I'm gonna get one of these:
https://www.shop-fortune-auto.com/collections/upgrade-accessories-and-replacement-parts/products/fortune-auto-remote-damper-controller
I know from past experience that after the first month I'm just not going to open the hood and trunk to adjust the dampers (except for those rare occasions when I actually make it to the track), this will make it so I can do that from the driver’s seat.
The following 2 users liked this post by WylieKylie:
mike33 (07-02-19),
redspencer (07-02-19)
