Brakes shakes when slowing down from high speeds
Old 04-30-19, 05:52 AM
OKC06IS250
OKC06IS250's Avatar
Default Brakes shakes when slowing down from high speeds
Hey:
I just had my rear rotors and pads done about 200 miles ago and now I feel shaking in the steering wheel and brake pedal when slowing down from high speeds.
The mechanic said the front pads had 50% life left.
I think the front rotors and pads need to be changed.
What do you think?
Thanks
Old 04-30-19, 06:43 PM
Mike_1GO
Mike_1GO's Avatar
sounds like warped front rotors. replace them and get new pads
ivanj (04-30-19)
Old 05-01-19, 02:11 PM
Gville350
Gville350's Avatar
Are you saying that BEFORE the rear brakes were replaced, that you didn't have this problem?
Old 05-02-19, 06:32 AM
OKC06IS250
OKC06IS250's Avatar
I did but it was not this bad.
Old 05-02-19, 02:28 PM
Gville350
Gville350's Avatar
First off, any time I get new braking components (pads/rotors/calipers), I always re-bed in the components by using the below procedure. After trying this, please report back and see if the problem still persists.
https://www.powerstop.com/brake-pad-break-in-procedure/
Old 05-06-19, 08:06 AM
OKC06IS250
OKC06IS250's Avatar
I tried to re-bed them and still the same issue.
I also tried to change the rotors and pads but can not get the top caliper bolt off. I used WD-40 and a breaker bar but I felt like it was going to strip the bolt.
Any ideas?
Thanks
Old 05-06-19, 01:22 PM
Gville350
Gville350's Avatar
^Well, you're kinda hinting at the root of the issue; it seems to be a seized caliper. That coupled with new pads/rotors can cause alot of issues. I had to replace both of my rear calipers after a new pad / rotor change. The caliper wouldn't fully release from the rotor surface and caused EXCESSIVE heat and smoke.
nerv81
RX - 3rd Gen (2010-2015)
04-18-18 06:08 AM
apdimitri
Suspension and Brakes
09-08-13 06:07 PM
kkohorst
13
08-04-10 03:27 PM
gs3Nic
07-26-10 03:27 PM
Rock-a-Lex
04-03-07 09:04 AM
Quick Reply: Brakes shakes when slowing down from high speeds
