2000 lexus gs 300 abs brake buzzing
I have a 2000 lexus gs300, the abs/brake light came on with a buzzing ....I replaced the master cylinder with all attachments...I replaced all abs sensors along with a new axle (rear passenger ) and a new caliper (rear passenger ) and the damn light and buzzing is still on. The thing that I did notice is the rear passenger brake line only drips fluid all the way from the master cylinder....there is no pressure ...how do I properly fix this I tried to have the car on so the module is pumping ...I tried with the car off like the old way ....I dont know what else to do....plllleeeaaassseee helppppp I cant take that buzzing noise and the fact that I have to put so much pressure on the pedal just to slightly stop
If you replaced the master make sure that you bled it and there is no air in the master. If there is its never going to work properly. For the rear passenger caliper take the brake lines back out and make sure that you didn't forget to take out a plug or something like that. If its a brand new caliper it should flow brake fluid very easily.
BostonVP
19
05-02-13 09:13 AM
