Torque specs for caliper bolts and caliper bracket bolts 2015 IS350 F sport
Greetings all,
I searched and didn't come up with this specific information. Any help or direction will be appreciated.
I'm getting ready to change pads and rotors on my 2015 IS350F RWD. Does anyone know the proper torque specs for the caliper bolts and the caliper bracket bolts?
Thanks!
Thanks!
Unfortunately with this posted in the Suspension and Brake section it likely got buried under other threads.
General forum would have yielded a response.
Front caliper to knuckle bolts - 100ft.lbs
Rear caliper bracket to knuckle - 92ft.lbs
Rear caliper to bracket - 20ft.lbs
Rear 2016 IS300 awd fsport
Front caliper bracket to knuckle - 100ft.lbs
Front caliper to bracket - 25ft.lbs
The rear specs are the same across all models of 3IS even thought the rear brackets and calipers are different on the 250 compared to the rest of the model line-up (which are all the same).
Jaydm (04-30-21)
