98 GS400 resurrection, where do I begin?
10th Gear
Long story short, gonna bring the 98' GS400 back to life.
However a wheel is cracked and the front suspension is totally worn.
I saw this thread here after lots of searching
https://www.clublexus.com/forums/sus...-98-gs400.html
OP mentions how great is Bilstein HD shocks are, those for sure I will grabbing.
But if I want to COMPLETELY redo the suspension back to OEM or better (not slamming it, or performance, I want it as luxury as possible). Where do I begin?
Is there a comprehensive list of things I can add in order? Like bushings, struts, shocks, etc. I'm not too mechanically savvy, but I do want the best or oem equivalent as possible.
What do you guys recommend?
Well, if you have the budget you can always go with air suspension, cheaper option would be coilovers and cheapest would be shocks and springs.
Rockauto has all of the oem suspension parts you may ever need.
10th Gear
Wow, I completely forgot I even made this thread like a dummy.
Now to get back to business since I set alerts to my phone.
She has roughly... 190k
All I'm looking for is a daily driver out of her, engine runs strong as hell. I mean absolutely zero issues outside of the suspension.
I did some homework on the GS series, apparently my issue with the front suspension and the shaking seems to be a common and known thing?
While I'm at it, I just seriously want to just knock this all out in one go you know?
I’m sure many things are worn out. You can always benefit from a set of new struts. The common problem is the lower ball joints and lower control arm bushings in the front lower rear trailing arm. You may just want to take it to a shop and have them tell you what all it needs. Then order it all yourself and do the project. You may have clunky sway bar endlinks, blown bushings, loose tierod ends and or inners, rack bushings blown out, upper control arm bushings and the ball joints. There’s wheel bearings to check for play/ noise. If the tires are old hard, worn, or cupped, the car will feel like crap until there’s good rubber and an alignment.
I don’t recommend coilovers if you want OEM quality ride. Bilstein and KYB are good strut replacements. Remember, there are spring seats, upper mounts, bellows, and bumpers on them that all may need replacement too. Don’t do lowering springs with OEM replacement struts and wonder why the ride sucks. They aren’t meant for it.
Have a look here. ROCKAUTO_GS400 They have an almost complete suspension kit from Mevotech at about $520. Can't comment on quality of Mevotech.
You'd still want tie rod ends, and a full set (front & rear) of Struts, and be sure to get fresh rubber mounting gear for the struts: Ozone in the air eats the rubber.
If it were me, I'd do what a friend calls base-lining, change all the fluids & filters -
Best of luck ! !
- Oil,
- Transission,
- Coolant (flush, then fill)
- Brakes,
- and with an age 21 car, I'd think about replacing the rubber brake hoses to each wheel before they give you grief.
Best of luck ! !
GS4DOUGIE
09-21-12 08:20 PM
qwerty04
02-13-12 10:31 AM
Quandry
08-01-03 07:30 PM
