Bilstein Sports and L-tuned Shocks: Pics side by side
This first pic shows the Bilstein (yellow) next to the L-tuned. Noteworthy is L-tuned's fully extended reach....which is shorter than the Bilstein's. As such, Bilstein will provide a longer suspension travel than L-tuned. The big BUT though is can it do that considering Bilstein's much stiffer valving rate versus L-tuned? If you use a spring with L-tuned shocks, front, the springs start at a more compressed state than if the same spring were used with Bilstein. Bilstein's construction appears more robust and of better quality than the L-tuned, judging from the outside casing.
The Bilstein rears are just a little bit more stiff than the L-tuned rears, which is unlike the fronts where the difference between the Bilstein and L-tuned is overwhelming.
Now, get this. the L-tuned rears have a longer fully-extended reach than the Bilstein. This is a complete opposite from the story up front.
Originally posted by jbbnet
did u change from bilstien shocks to ltuned? if so, y?
Originally posted by whitels
Yes I changed to L-tuned for a little bit more ride comfort.
Were the bilstien stiffer?
Did you feel more bumps with the bilstien?
Short answers-- yes and yes. I had extensive reviews here a while back. Use advanced search for my postings under GS suspension.
I was told my SSR's were rebuildable 3 piece wheels, but it was more than a cost of a new wheel to rebuild them since it can only be done by SSR Japan.
