2017 IS350 Brake Squeal
I knew this would happen. Instead of opting for a $400 brake job from the dealer, I went with my local trusted shop and had them install Lexus brake pads for less than half of the cost. Of course, I'm now experiencing the same thing that as when I had them do the brakes on my 2015: the brakes squeal briefly for the last few inches of the stop. Not every stop, but probably about 30% of them. When I took my 2015 back to them last time, they messed with the brakes but said everything was fine and there was nothing they could do. I don't believe it. They must have done something wrong, both times. By the way, it was fine for the first month or two, but I don't believe the solutions I've found about it being dirty or rusty brakes. This never happened during the first 25k miles on any of my other IS350's.
I know very little about brakes. Can anyone give me any ideas on how to get this fixed? It sounds so ghetto, it makes me really hate the car.
Received 1,738 Likes
Did they replace the pads and rotors, or just the pads?
If there is any rust on the very edge of the rotors where the edge of the pad ends, then this will cause the noise you have.
Either replacing the rotors, or machining them, should resolve the issue.
Filmneye (07-02-23)
I believe the rotors were turned. It was the first brake job, the car has only 25k miles. Thanks for the advice.
Perhaps, they didn't apply anti-seize compound on the shims or on the brake contact points between the pads and the shims. It's very important to clean the calipers (wire brush for rust build up and then cleaning with a brake cleaner) and use a quality silicon paste for the brake pins. I personally use 3M silicon paste for the pins and Permatex anti-seize for the contact pins. I've been changing brakes for the past 8 years, and never had issues using this method
Filmneye (07-02-23)
Either way it's definitely not the best machine job.
The pic is a little far away to be sure on the rust...yes for sure there is rust on the inner and outer edges, but that could have happened if the rotors were recently wet (rain or car wash) and then allowed to sit for several hours before being driven.
Depending on how much rust, it could have been left from the machining process whereby not enough material was cut off to eliminate the rust.
Unfortunately the pads aren't designed to go to the very edge of the rotor, so there will always be a very tiny edge where the pads don't touch...but if rust forms on that tiny edge, then it can lead to brake noise.
But given the actual surface of the rotor, which pretty much looks like a**, I would just replace the rotors at this point. If the rotor was thick enough, you could machine it again, but you can only take off 2mm in total, so 1mm per side of the rotor...which isn't a whole hell of a lot.
Filmneye (07-02-23)
I know 100% that in my case, it's not the weather. Never happened before the brake job. Same thing happened when I did the brakes on my 2015 IS at the same shop.
Filmneye (07-02-23)
So Lexus service inspected the brakes along with everything else for a 30k service and they discovered that the shims were missing. The shims from the old brakes were supposed to be re-used, but the shop I used discarded them. I believe this was a huge contributor.
Lexus also has a video explaining why brakes might squeal: https://www.youtube.com/watch?v=Ff5h...ature=youtu.be
Filmneye (07-02-23)
I neglected to mention that the service advisor also told me that the inside and outside pads are not the same but can easily be swapped. This can also cause noise.
So just keep the shims that are currently installed and move them over to the Akebono pads when putting them on correct?
That is what i did @ 500 miles and the shims was very easy to clean. I applied the grease that came with the Akebono pads in the between the shims on top of the thin layer of padding.
Noeh (01-28-20)
