BBK: upgrade stock IS250 Brakes to 2019 GS350 F-Sport Brakes
2013FSport (02-14-20)
Here it is, the almost final product. I used 20mm spacer but couldn’t get enough clearance despite -3 camber. Plan to try 15mm spacers, perhaps shaving a bit off the caliper while being extra careful not to penetrate into the core. It’s still a working progress but I’m getting there
I really don't want to run spacer but unfortunately, it didn't clear the barrel of my wheel, even though I have O disk. Now i'm running into even more clearance issue with the 20mm spacer. I will likely have to create a more negative camber, maybe shave down on the edge of the caliper and try 15mm spacer. Any suggestion is appreciated
Well, if you're caliper is touching the wheel spokes, additional camber won't affect that. Here's your options :
1) on factory studs, run a large enough spacer to clear the caliper/spokes
2) install ARP lug studs and run any spacer safely
3) grind away on the caliper in hopes you don't hit a fluid passage
4) use a different set of wheels that will clear the caliper
Wish you luck!
Wish you luck!
Wish you luck!
Wish you luck!
Factory 18" wheels should clear these brakes without issue. Aftermarket wheels may have issues unless they are 19's (for 2- or 3-piece wheels) or have spoke designs with decent caliper clearance (for 18's or larger).
Another item that should be mentioned is that the aluminum hats on the 2-piece rotors are not designed to accept steel wheels. This isn't normally an issue, but can come up when needing to use your spare tire. The IS spare will not clear these brakes and is a steel wheel. If using these brake rotors, you should use an appropriate aluminum spare wheel. 42611-30F41 is the correct wheel to use with these brakes with a T145/70D18 tire.
For backing plates, 47781-53050 and 47782-53050 are the correct backing plates when using these brakes on a RWD 2IS.
Jeff
Jeff
Jeff
Jeff
i trimmed it to accommodate the caliper, then bend it back to avoid it from hitting the rotor. The GS350 dust shield have different mounting point so i can't use it. one option is to switch it out with the ISF dust shield. however, not sure if ISF rotor is 13" or 14".
