SC400 OEM Struts/Springs
I've noticed that there is an early strut and spring part number and a later.
Basically a 92-96 strut and then a 97-00 strut. Same with the springs.
Does anyone happen to know what the difference is and whether the later part numbers could be used on a 92 SC400 car? Some of the early stuff is discontinued and I'm looking to keep it stock.
I believe it all should bolt up no problem. Someone please correct me if you know anything else to be true.
RudysSC (04-03-20)
This is great information. I too ran into this issue as the 96 front struts are discontinued as well as the front strut mount brackets. However, for the 2000 Lexus SC400 models, I found the following at discountpartsmonster.com
front struts-------------Shock Absorber - Lexus (48510-29505) $69.41
front strut mounts----- Mount Bracket - Lexus (48681-24030) $102.71
front bump stop-----------------Bumper - Lexus (48331-24030) $25.09
Can someone chime in and verify that all these components from a late model SC400 will work on earlier models?
Are you sure those are actually available? I'm betting no. As for fitment should be good but someone can confirm.
