RCF/GSF Brembo Brakes on IS 200t FSport
#63
#64
Who has your RR Racing brakes now?
#65
and done! loving them so far. comparing them to rr racings kit (wilwood calipers & rotors) i would say the rr brakes have a better bite, but tend to have a lot of fade and on certain days the bite was off. overall this is oem which is what i wanted and of course the F brembo orange combined with ultrasonic blue!
#66
To the OP thanks for the work and for sharing. I can’t seem to find them in any other color but orange. To “jmull3r” how wide are those 19’s and what offset are you running. I can’t decide if I want to go 18” or 19” which will also determine if I go with the oem Bbk. Your guy’s cars look good.
#67
Checking to see what the long term reviews have been for doing the GSF upgrade vs ISF Caliper upgrade? Is it an upgrade that you regretted or would do different? As in terms of fitment of the factory IS350 wheels, Will they fit back on for winter wheels or do you need to run a spacer on them? I have a brand new set of LC818's with Continental DWS06 off of my 2G IS350 I just recently traded for a new Infinity QX60 Limited. I stripped everything off of my IS350 when I traded it in with plans on trading my wifes 2015 QX60 in for 2019-2020 IS350 at the end of this summer and swapping cars. Original plan was to buy New ISF calipers with the GS350 Cross Drilled Rotors for the front and be done but then I stumbled across this post and found that the GSF Calipers and Brembo rotors are very cheap now, look way cooler but I will be limited to running my LC818's year round. My biggest concern is bending a rim here in PA and not having the OEM wheels and tires as a backup but that is the trade off. I have not fully committed to buying another IS350 yet because my kids are both teenagers now and hated the size of the IS350 and I might go with a GS350 F-Sport this time. I'm really leaning towards Jmull3r's setup since it seems to be a cleaner setup with all OEM parts and can be used on both IS350 and GS350's..
#68
#69
No difference works the same RWD/AWD. You'll need the bracket for the rear and shaved dust shield. Front bolt on but remember withe GSF/RCF you'll no longer be able to run your stock wheels. As the front will only clear 19"+ size rim. If your like me with AWD and swap summer to winter setup. Go with ISF front and RCF rear caliper. To fit the ISF up front you'll need to get GS350 Fsport rotor must be Fsport or it be to small.
mmayo3is (08-08-22)
#70
#72
So after a few minuets of digging. You get the same look with ISF Brembo. Should clear 18” and f-sport wheels.
so it looks like you can use ISF calipers front on 18” and rears, GS350 rotors front ISF rotors rear?
LEXUS ISF BREMBO BRAKES
INSTALLATION FOR LEXUS ISF BRAKE CALIPER ON VARIOUS LEXUS APPLICATIONSREQUIREMENTS
PARTS
- Front and Rear OEM Brembo ISF calipers
- Front 2013 and up GS350 F Sport rotors (356mm x 30mm) *cannot use ISF front rotors
- Rear ISF rotors (345mm x 28mm)
- 350phi Rear bracket mounting kit
2013+ LEXUS GS350 F-SPORT 356MM FRONT ROTORS
- OEM toyota:
- OEM 2pc discontinued rotors:
43512-30371 or 43512-30370: Disc, Right 2pc rotor
43516-30061 or 43516-30060: Disc, Left 2pc rotor
OEM 1pc steel rotors:
43512-WY010: Disc Right
43516-WY020: Disc Left
NOTES
- Will require modifications to front and/or rear dust shield
- Will require modifications to rear calipers
- Will require wheels 18" and up that can clear big brakes
- Will clear F Sport wheelS
