rotors & pad option
rotors & pad option
Hello all,
i saw quite a few of post regards to changes brake pads & rotor in every 20-35k(depends on how you drive) and now it's time for mine to be change out.
Option i'm consider is
Pad: Akebono ASP1118 Front and ACT 11391A Rear ( no idea why they don't have ASP1118 rear)
Rotor: R1 Concept Geomet Drilled//slotted all around.
Rockauto got another few rotor such as power-stop, Centric and a few other... should i go with R1 or consider other options?
The car is my daily and trying to avoid brake dust as much as possible with decent stopping power.
Just recently installed some Powerstop rotors and the stud holes on rotors seem to have been drilled a bit too big? The rotor has some room to move around so my car to has a slight vibration now when braking...
Received 1,738 Likes
Just wondering how your stoptech rotors fit? Any wiggle room when mounting them? Are they a tight/snug fit?
Vibrations when braking at high speed is usually caused by warped rotors...however rotors can warp for a number of reasons, or even come that way from the manufacturer.
Rotor holes will never be tight to the studs...you should be able to turn the rotor a couple mm's in each direction.
I have encountered this with non-OEM rotors before also, however I did minimise vibration by loosing the wheel nuts a little maybe start with 10-15% initially while the wheels are still on the car and going for a short low speed drive then tighten them back to spec help located the aftermarket rotor more centred to the wheel hub... but next brake change I went back to an OEM rotor for this reason. Just curious do these rotors outperform the OEM advics rotors or was your choice purely cosmetic?
Honestly maybe just a tab bit better but barely noticeable. If anything it was more for cosmetic but after trying aftermarket brands I’m surely going back to OEM to get the smooth quiet feeling again..
Ling2IS
12-17-16 05:50 PM
jbone29
Suspension and Brakes
01-02-13 12:09 PM
passnu2
01-02-11 05:28 AM
