Eibach L Tuned Suspension...from Rod Millen...will this damage my car?
Old 09-21-03, 08:55 AM
koreanpers
koreanpers's Avatar
Default Eibach L Tuned Suspension...from Rod Millen...will this damage my car?
L-Tuned Performance Strut Set and Eibach Lowering Springs... i was told these will lower my car by about 1 inch all the way around. Will this give me a bad camber? will my tires wear abnormally..or will this not be that bad? Has anyone else tried this combination of suspension?
Old 09-21-03, 03:53 PM
lexforlife
lexforlife's Avatar
bad camber will be a given for now until daizens camber kit is released very shortly
use a good alignment shop and they can max out the eccentrics enough to not make the neg camber not beyond -.5 degrees .. wear on the tires will be minimal if you keep a eye on proper inflation
Old 09-21-03, 04:06 PM
Letsride
Letsride's Avatar
So Lex even with the 1 inch drop there will still be camber issues?
Old 09-21-03, 07:19 PM
lexforlife
lexforlife's Avatar
i cant say everyone will but i do have slight neg camber and my friend eliel who also uses the ltuned susp has as well and blue lex has it up in west palm so eccentrics seem to get maxed even with a 1 in drop
Old 09-23-03, 11:05 AM
LEXISM
LEXISM's Avatar
would this be the same outcome with coilovers and what kind of springs and struts does ltuned use ?
Old 09-24-03, 04:15 PM
Letsride
Letsride's Avatar
Lex thanks for the info. this is getting so complicated. I thought I had this all figured out but I guess anyway I go I will have camber issues.
I was planning on going with L-tuned shocks, Eibach springs and Daizen sways......now back to the drawing board.
Old 09-24-03, 04:37 PM
Neo
The One
Neo's Avatar
With a 1" drop, you should not really have problems. When I had the Ltuned S/S set up, I had no problems and no inside tire wear. Just make sure you use a good alignment shop.
Now with Tein and a bigger drop (not slammed), getting good alignment is challenging but it is still acceptable.
If you are just doing 1" - 1.5", I'd say go for it. It is when you get to the 2"+ that you should pay some attention.
Old 09-24-03, 05:33 PM
koreanpers
koreanpers's Avatar
cool, i found some l tuned shocks w/ the eibach springs for around 150
Old 10-06-03, 08:58 PM
martialart
martialart's Avatar
i have the same set up - its a good choice, but my neg is only .1
istundra
Suspension and Brakes
23
05-24-08 11:26 PM
daltexlex
11-29-07 12:41 PM
CinFulxgs
07-20-05 10:57 PM
LEXISM
07-14-05 04:38 PM
Blanco
08-05-04 09:57 AM
Quick Reply: Eibach L Tuned Suspension...from Rod Millen...will this damage my car?
