92 sc300 hub bore size
10th Gear
Hello guys, I've been a lurker on here for a while now and I finally made an account. Sorry in advance if I posted this in the wrong place.
So I need some spacers for my 92 sc300. I researched the spacer specs needed and I ordered some 20mm with 60.1 bore size and when I went to install them they wouldn't fit. Does anyone else have a bigger hub bore size on their sc? If so what size is it? Thanks.
They are all pretty much 60mm on the bore... have you measured the bore on the spacer? Maybe the spacer's bore is incorrect....
The 60.1 is correct for a ‘92 SC IF a previous owner did not do a mod to the more common 70 that most wheels are sized (which is where hub rings come into play).
Spacers can get away with being larger but best to size it correctly….. 20mm sounds pretty big so your offset on your wheels must be no where close to what you want….
Hope you are able to address this safely.
