I want my car to sit like this
Registered User
I want me car to sit like this
Wassup,
What type of setup can i get to make my car basically sit like this one in the pic....
Looking at the pic the rims look like 20s wrapped in 255/35's
wat kinda setup suspension setup can get my car to sit like this one?
thanks
thanks
Do you plan on drviving the car?
I can tell you from experience that your SC will be USELESS at that height. That is STRICTLY for show.
The only way to achieve anything close to that (correcty) is to get COILOVERS. And for going low, I would only recommend pre-load independant height adjustment coilovers...JIC FLT-A2's and Tein FLEX come to mind...for not too low, you and use pretty much any coilover system or even springs if you're a noob that's going to regret it later.
The wheels are 19" and running a 255 up front would be BAD, BAD idea. As it is, with 245's, you can still have serious rubbing issues with the car that low (or almost that low). The SC does NOT have very well designed front fenders (for lowering).
I would HIGHLY suggest you do a search and/or read around as I have posted many times about lowering a SC on larger wheels....
Kevin
Originally posted by aliga
what type of lip is on that car?
Wald executive... http://210.198.3.77/wald/catalog/executive/soa30_1.html
245x19 and 275x19 can be used with out rubbing,just trim off the 1 inch lip in the wheel well and slam the car on coilovers ez..make sure you have right off set on wheels so that it can tuck in as you lower it..
Originally posted by lexcoupe
manny. I got supra TT wheels, i know they arent 19's buti have 255's all the way around on a TEIN CS (all the way down in the front) dropped SC and there is no rub at all. I know it would probably be different on 19's but for me there is no rub with 17's and 255's up front. My car also isnt that far down up front. I dont have a wheel gap, but my tires arent tucked like that SC.
Kevin
Kevin
Have personally seen 19's (with 245/35's) and my 20's (with 245/35's), I can tell you that they rub hard on the inside fender when the car is anywhere near that low especially when you hit a dip or bump or anything that causes compression of the shock...I had my wheels bearly tucked for one day and it was useless. Then again, I also have a body kit that lower the front and makes it stick out a little further so that doesn't help getting up driveways and such...the SC's front nose is just too long (that's why Lexus removed that black lip on the '94+....)
What sidewall height do you have your 17's? You might be running lower profile tires then normal and that will prevent inner fender lining rubbing....it's no so much the edge of the fender, but the inside of the fender. Have you taken off your wheel and looked at the inside?
Kevin
you need air.................
The cars you see that have the very aggressive stance like the pic you posted, either aren't driven or have air ride! If you enjoy your car and you want it to look like the pic when it is parked GET AIR RIDE! That is the only way it will happen, not my preference but to each his own.
Jimmy
Jimmy
Originally Posted by ginessgold
Wassup,
thanks
thanks
Originally Posted by stevechumo
By looking at the car, I think it's possible to get 245/40/18 for the front and 255/40/18 for the rear. 275 is totally not recommended. But you also have to cut the rear inner fender well to prevent rubbing on tires. For lowering, you might use Tein coilovers or you just save money but with the same performance and look by using a set of Tanabe NF210 along with a net set of Tokico shocks. However, you have to cut 1/2 coil for the front and use the whole shock bump stop for the rear. The gap between the fender and the tire is about 1.5 fingers all around. This way, it looks like you're using coilovers because there's no lowering springs can give an even height all around. Also, it rides smooth like stock. I'm using this setup on my SC400 with Vis body kit. It's a little low when pulling out from the driveway to the street but it's doable with skill.
