upgrade bbk from is350 to 250
i have 2011 is250 so i just install the 4 pistol caliper and rotor brake from is 350 and after installed it break amazing but now when i turn at the corner or make slightly turn it making noise. Does anybody know the issues ? by the way the rotor and brake pad are used. Thank in advance
Take off the wheel, and tighten the lug nuts on the rotor. Afterwards look too see where it's rubbing on the rotor. At this point you can bend the areas with a flat tip screw driver. Remember the lug nuts will bottom out first before actually putting the rotor in the correct mounting spot. So you'll have to bend the shield back slightly further.
For me it took about 2 tries per wheel. Note be aware to look at the outer tie rod bushings. They are really close to the shield. Try not to bend that area too much. Otherwise you risk the bushing boot to melt if it's touching.
currently i run without the break dust shield bc it dont the caliper dont fit so im getting the shield of the is350. Should i resurface the rotor?
