coilovers
coilovers
Hello
I'm hoping to get opinions and or advice from people that have or used coil-overs on their Gen 2 GS 300..
I'm thinking about putting them on my car, but wanted to get insight from people in this group.
Thanks
Thanks
They are nice for lowering and better handling, but at a sacrifice of OEM comfort. Also can be a cheaper alternative to replacing blown struts. Think about your plans for the car when looking for a set though. Cheapest isn't always a good thing. Do you need adjustable dampening? I use the Tein street basis z set which are ride height adjustable but not dampening. They (at least at the time) were a very affordable set that served the purpose of lowering the car, refreshing blown struts, and retained drive-able manners with a matched spring/shock for street use. You will also need an alignment and it is recommended that some spacers called "RCA"s (roll center adjusters) for the front lower ball-joints are installed to aid in proper alignment and handling. If I did any racing or track time, I'd have upgraded to a quality name set with full dampening adjustments though. I just don't see a need for it in street use with a good matched spring/shock. But it depends on what you plan for the car and what it will be used for/driven like.
QLex300 (03-16-22)
I want to lower slightly where its barley noticeable and still keep the comfort of the car.
When I got the car, it had lowered springs already on it and rides kinda ruff and I want this to be my daily driver compared to my expedition.
Not looking to have lowrider or where they have the wheels leaning in, I just want to lower and have a ride smooth as possible even though the suspension will change when its compromised.
I'm look at some shocks and struts.
As ALWAYS I APPRECATE your advice and input!!
