SC400 Coilover spring and dampening rates
Hey guys! Starting to build my 96 Sc400. I purchased Silver Neomax coilovers and play on dropping my car 1.5 to 2 in. Does anyone have good numbers for spring rate and dampening for street use? Don't want to be rolling around with super stiff suspension
Thanks for being a friendly community and all the helpful info!
I have 12kg front and 8kg rear on my Fortune Auto Müller MSC-1 coilovers. They recommended 14/10, but I wanted a more compliant and softer setup, so I went with this. I’m probably a little past half way stiff on the adjustment *****. The lower you go, the higher the rates need to be, to prevent you from bottoming out the suspension. So far, I have not hit my bump stops, but I admittedly don’t drive aggressive and scan the road for bumps.
This is my drop:
![](https://cimg2.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/47ab1062_6ec9_453a_87ca_d4db915b1eea_76efd72abeeb9d96c2a494666e5cc1b86c47e1d2.jpeg)
![](https://cimg2.ibsrv.net/gimg/www.clublexus.com-vbulletin/1024x682/9be86de3_65c9_4cd7_9074_5d83b8b74c3a_ba69d8adab5ebfe0b004486ddfda398254b243ba.jpeg)
I don’t know how much lower it is than stock, but it’s an 18” rim and 26” tire front and rear.
Nick
