Lexus IS 2015 base model suspension
2nd gear
Whats up Lexus fam
I have Lexus IS 2015 base model I have some issues on my car ,
my car has leak on front right side suspension
My question Is it necessary to change all 4 suspension?
is f sport suspension better than base model?
What are the benefits of changing stock bushing with RCF bushing
F sport comes with adjustable dampering so I'd assume the strut is different, stick to the base model strut (check the part # and compare them)
If you have 1 shock leaking (front right), I would change the front 2 and leave rear alone.
RCF/GSF bushing is made of a stiffer rubber compound which helps with steering response and improves inner tire wear
