08 IS 250 awd shocks and lowering springs vs coilovers
10th Gear
2008 IS 250 base awd
no modifications
budget<$1,000
located in Nebraska, US
Daily driven
goal is to lower the car for aesthetic purposes
TL;DR: Fsport shocks with H&K lowering springs vs Megan racing coilovers?
My research had led me to believe that Shocks with lowering springs would be my best option because I have read that even with expensive coil overs you sacrifice ride quality. Then I found a post on here praising the hell out of Megan racing coil overs saying that they have great ride quality. At the cost of about $1,000 for F sport shocks and H&R springs, the Megan coilovers for $750 are seeming like a better option. I also like the idea of raising the car for winter, as the salt and snow here is terrible.
Is the ride quality of Megan coilovers really going to be that much worse then f sport shocks paired with H&R springs?
I have used tokico coilovers before on an Acura cl, and multiple brands of lowering springs with stock shocks, so I’m familiar with a poor ride quality.
is there a new consensus on the quality of Megan Coilovers that I missed when researching?
no modifications
budget<$1,000
Daily driven
no modifications
budget<$1,000
Daily driven
My research had led me to believe that Shocks with the lowering springs would be my best option because I have read that even with expensive coil overs you sacrifice ride quality. Then I found a post on here praising the hell out of Megan racing coil overs. At the cost of about $1,000 for F sport shocks and H&R springs, the Megan coilovers are seeming like a better option. I also like the idea of raising the car for winter, as the salt and snow here is terrible.
no modifications
budget<$1,000
Daily driven
The AWD drive max you can lower is 25.75" fronts, rear maybe 26.25". That's my setup now and I really enjoy it. I'm running 245 40 17 tires on Enkei's OEM offset. I get no vibrations so I'm more than happy with it being lowered.
It all comes down to personal preference of how much harshness you can tolerate. I do get complaints of people when I loan my car. Some say I hate the stiffness of your car. Others the suspension is really tight.
10th Gear
I cant say how much it will affect comfort. Since long ago I did so much suspension modification. It's more like I'm driving a go cart now. Though I can say the BC's I just installed are slightly stiffer than the OEM suspension. They now are just barely broken in. Not too harsh, and not too soft.
as nice as BC coilovers seem, I would have a hard time purchasing them over the Megan’s if all I get is more settings. I don’t want to track the car, so I don’t care about more then ride height really. My main concern is I have read horrible things about Megan’s coilovers, yet when reading a thread here I found the opposite
Once you install them just dial them in. Also they will be softer since you will not be running after market sway bars. Though if you plan to slam the AWD. You will bust the cv axle boots, and get vibrations. So prepare for that, and you'll want stiffer spring rates than default to accomplish that.
10th Gear
I ran them on my old GS400 they're decent. If you don't want to track the car just get default spring rates. The BC'S are just beefier compared to the Megan's.
For the Megans , the spring rates are fixed , as there’re not customizable. I’ve had H&R springs paired with OEM shocks and the ride was very smooth , outside of big dips on the freeway. Ive been on Fortune Auto coilovers now for about two mobths and feel that they provide a greater ride than the spring set up. ( also running 19” wheels, Figs rear sway , and RCF front bushings now). Lastly , I’m not 100% sure F-Sport shocks are still available for purchase any longer.
10th Gear
bbaugher47 (10-05-22)
10th Gear
My car has 127,000 miles and the shocks feel great, which makes me want to say that they were replaced at some point
My car had like 35k when I bought it 7 years ago. So I had low mileage shocks on her. But the rear passenger shock is known to be a weak point on the second gen. And yeah, Fortune Auto is a great company who makes a fantastic product.
10th Gear
At those spring rates combined with the ****ty roads here in Nebraska, lowering springs are seeming like a better option
I did further research about spring rates and I’m very confused. The Megan’s have 10k F 8k R rates, but that is nearly twice as stiff as stock rates. From what my research told me that is more along the lines of track stiffness, and would be a very poor ride quality on damaged roads. My brothers gls turbo beetle has 5k and 6k, and that is already stiff as hell. Are you saying that the Megan’s at 10k 8k would still need to be stiffer to fully lower the car??
10th Gear
you can't compare a beetle spring rates to Lexus IS250/350/F or any other car, cuz geometry is different and design is different, you can only compare the same car or same suspension layout like a 3GS or Mark X... as far as ride quality I found my HKS hipermax rides amazingly well compared to BC...
