Front/Rear Suspension Refresh
4th Gear
Doing some suspension refresh,needing some inspo/advice
Fs is the front upper and low control arm and rear lower control arm
Planning to go with battle version since I heard good
things
Gonna replace front and rear sway bar end links and outer tie rod using battle version aswell
Couple things I’m wondering,
Y’all got any good ideas about where I can find a inner tie rod? Couldn’t seem to get one on the bv website,
Y’all recommend bv? Or is there a suspension company that does the same stuff for cheeper
And where to get some good poly eurothene bushings,when I air out it puts natural camber and stresses the stock bushings out,
Also in yalls opinion..stock or aftermarket differential bearings
And finally anything else y’all recommend suspension wise for thr 158k mile mark? Thank you!
(Not a drift car/drag car,just wanting to get some suspension components that will last,and make the car ride a lot more smoother)
1999 Bagged Lexus Sc300 Auto 2jz-ge
1991 Mazda Miata M Edition 1.8 Turbo
things
I'm using this video for reference since I just cruise and looking for a refresh on my SC400
https://youtu.be/ittZpnQ1rRQ
Kyl305 (10-17-22)
OEM Rear Traction Rods identical on both sides?
Thank you
w84me
ES - 5th Gen (2007-2012)
10-14-20 02:08 AM
