Wheel hub & bearing
Old 11-21-22 | 06:22 PM
Corralesr's Avatar
Corralesr
8th Gear
Default Wheel hub & bearing
Wheel hub and bearing issues, need to be replaced but I can’t find a wheel hub and bearing pre-pressed. I’ve look everywhere. Please help. As I need that fixed asap and push in the right direction is needed! Thank you in advance.
I have a 2002 Lexus gs430
Old 11-21-22 | 06:29 PM
There is no such thing the bearing must be serviced with a press, or if you go caveman a slide hammer, Hub Tamer like tool etc.
Old 11-21-22 | 06:32 PM
Corralesr's Avatar
Corralesr
8th Gear
Default ???
So if I buy a wheel hub & bearing assembly kit it will come together already? My mechanic says he needs a bearing press to press the new bearing into the new wheel hub?? It makes sense but I’m not sure if he really would need a “press”
Old 11-21-22 | 06:40 PM
Picture is worth a thousand words (don't buy this brand)
https://www.rockauto.com/en/moreinfo...&pt=1636&jsn=8
Generally to do this job you need a new bearing and seal. Unless you can find a Koyo bearing at the various parts outlets buy from a dealer. Which is a Koyo bearing. Your mechanic is right to do the job properly a hydraulic press is preferred.
Old 11-21-22 | 07:30 PM
Corralesr's Avatar
Corralesr
8th Gear
okay so my problem is my mechanic does not have any type of press. So maybe if I buy the parts take off the knuckle, and take it too a shop then can pull it off and put it on for me correct? I will have to pay them. Or can they even do that
Old 11-21-22 | 07:41 PM
Some shops will do that but you'll have to ask. It's a good plan I've done it a few times before I had a press. Here are part numbers for reference.
http://www.japan-parts.eu/lexus/us/2...eering-knuckle
Old 11-23-22 | 11:03 PM
firelizard's Avatar
firelizard
Go to a different mechanic.
Old 11-24-22 | 10:13 PM
BayAreaLex's Avatar
BayAreaLex
Find out who services Lexus in your area and take it to them to solve your problem.
Replacing a wheel bearing shouldn’t be rocket science for any competent Lexus mechanic.
snakeo2
10-29-19 09:34 PM
SNiiP3R
06-03-09 05:01 PM
amdspitfir
12-17-08 09:46 PM
ARISTO 161
Maintenance
12-18-06 03:53 PM
SlowGS3
GS - 1st Gen (1993-1997)
01-21-06 02:26 PM
