AFS Light Flashing After Tanabe NF210's
#76
Sorry for the Hella BUMP but damn! this thread HOOKED me up! my arm did not need the full 90 degree bend but thanks to smalldog for the pictures, i got what i needed. oh, and just to let you know, this worked like a charm on my 10 IS250C. Only one leveling arm in the left rear
#77
Just wanted to ask, does adjusting the AFS like this have any negative effect? I guess what I'm asking is if your doing the turn-the-screws-in-the-engine method or the AFS-10mm-adjustment-nut method, do either of these affects the AFS differently? Don't want to burn my AFS out lol
#80
I'm using the same image from the previous post just to give you guys an idea.
It's the top 2 nuts where the sensor with the plug and the top elbow that I can't tightened.
#86
hey guys if someone can help me out a bit, my AFS lights is constantly on, reading this forum i took my rear driver side wheel off and found out that me bracket was is bent as shown in picture. my question now is which nut/bolt should i unscrew to fix the bent bracket into a L shape. If someone can refer to the from 1 to 4. 1 is the top bolt by the sensor and bolt 4 being at most bottom.
#87
Im on Air, and I run into this from time to time when I work under the car. Just follow the pics and your good
Loosen bolt 4 and point bracket vertical. Looks like it was moved to an angle from your pictures.
#88
okay so My AFS light was on, ( not flashing like i been reading most guys have) I checked my rear driver side lever and yes it was bent, i straighten it out and made it into a L shape and still i have the light on AFS, any ideas why the AFS lights still on?? headlights work and seem like they do more up when car is started, gos up a little
