gs300 lowering tanabe df210
i lower my gs300 2000 with tanabe df210 i have 19 on my gs, my car looks amazing and it rides so sporty like, if you are like me and you are hesiting on doing this upgrade to your gs well dont be. it took me lots of research to make sure that this was the perfect thing to do to my baby, i have no regrets the ride is very very minor stiff but nothing to be worry about, today im putting a camber kit on it and i will be all set, while your at it change your struts i put kyb.
I just talked to the boys at Tunabe and asked them if a camber kit was needed for the DF210'a and they said it is "not." So I double checked my concerns and called Lexus and they said with that kind of a drop the camber would be off about 1 degree which really isn't anything to worry about. So basically my tires would have to be changed about 1000 miles earlier than if stock. I think I can live with that. ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
I will be dropping my car soon with the DF210's, I cant wait, just around the corner.
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
Originally Posted by 4thone
I just ordered NF 210s for my AWD.With the lesser drop I shouldn't have camber issuse?
With the NF's, the stock camber adjustment is sufficient to bring within spec, but BARELY! As it is I have 10,600 miles and my Advans are starting to howl, and I've been rotating them every 2,500 miles or so...
Still, well worth it.
I will be dropping my car soon with the DF210's, I cant wait, just around the corner.![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
Originally Posted by nardeezy
You will have more negative camber, have the guys performing the alignment adjust the camber. The GS has a camber adjustment on it, no need for a camber kit.
There is a camber adjusting kit on the gs????
Sorry, let me be clearer. There is no camber adjustment, but the mild drop with the NF's keeps it barely in spec.
