Suspension Springs, shocks, coilovers, sways, braces, etc.
Best Springs For '06 Gs300 Awd ?
Old 05-03-06, 12:40 AM
Mixman
Mixman's Avatar
Default Best Springs For '06 Gs300 Awd ?
Which are the best springs for a moderate drop on a 06 GS300 AWD ? I will probably go with 19" rims and tires, so what would go best with that combo ?
Old 05-03-06, 07:58 AM
nardeezy
nardeezy's Avatar
You're limited to a coil spring upgrade only. As far as I know there are no coil over setups for the AWD. I have the Tanabe NF210's and I think they're okay. I don't think anyone else has tried any other coil springs on the AWD. I have 245/35/20 and 285/30/20 tires and it rubs in the front when it bottoms out and when making a full right turn. It only rubs on the plastic lining so that's not bad. When there are heavy guys in the rear it'll rub when it bottoms out in the rear. It rubs on the inner part of the wheel well. It doesn't rub on the fender at all. I would recommend getting custom wheels to ensure the offset is perfect for lowering.
If you run with 245/35/19 tires all around or 285/30/19 in the rear with the Tanabe NF210's I don't think you'll have a problem at all. The reason I have the rubbing is because the rolling diameter is larger than stock, car is lowered and sometimes there's a lot of weight in the vehicle. When I am the only one in the car it doesn't rub that much (maybe less than 5% of the time on a trip) and depending on the road conditions.
Old 05-03-06, 08:39 AM
Mixman
Mixman's Avatar
Thanks Nardeezy. I am thinking of running 245/19's all the way around with the NF210's. Would that be a good enough drop with those wheels , or will it just look awright ?
Old 05-03-06, 10:53 AM
nardeezy
nardeezy's Avatar
It depends, 245 what? You can run 245/35/19 or 245/40/19 all around. What stock tires do you have right now, are they the Dunlop SP5000 DSST runflats?
Old 05-04-06, 03:26 AM
Mixman
Mixman's Avatar
Yeah, I have the 225/50/17 Dunlop Runflats. I am going to drop it at first. Then in about a month get the new rims and tires. I am going to go with the 245/35/19 as they match the size of the stocks the best.
Old 05-04-06, 08:24 AM
nardeezy
nardeezy's Avatar
Here's the weird thing, Dunlop has the stock runflats on an AWD spec'd at a 27.1" rolling diameter (17x8 wheel). The stock wheel is 17x7.5 but the .5" difference in width would not make a difference in rolling diameter. The RWD stocks (Dunlop 2050 or Yokohama ADVAN) are spec'd around 25.9". My 20's are wrapped with Dunlop SP9000 tires, spec'd at a 26.8" rolling diameter, which would be closer to the spec of the AWD stock wheel.
If Dunlops spec's are correct then you could possibly alter your spedometer if you go either way. A 245/35/19 tire is spec'd somewhere in the 25.9" range (I think). When I contacted (by email) Dunlop technical to verify if those numbers on the website are correct they said yes.
So, I am not sure what the stock rolling diameter is for an AWD. I am thinking that Dunlop made a mistake and it should be 26.1" for the SP5000 DSST tires but I verified it by contacting them. However, I am not sure how valid the infirmation is from the person who contacted me.
Dunlop SP5000 DSST (AWD OEM tire)
http://www.dunloptires.com/dunlop/di...00000&zipCode=
Dunlop SP2050 (RWD OEM tire)
Old 05-05-06, 10:30 AM
4thone
4thone's Avatar
I am happy with the NF210's and I think the 19's would be a perfect fit.
Old 05-05-06, 11:44 AM
Mixman
Mixman's Avatar
I looked at every other 225/50/17 tire that Dunlop has and they are all 25.9" It is either a typo and the person you spoke to just reread the typo or it's because this runflat happens to be taller.I suspect it is a typo beacuse no other 225/50/17 tire measure that high. I'll still get the 245/35/19 cause that's close to the height it should be.
Polo708
07-29-22 04:51 PM
Sammie
Suspension
12-29-08 09:27 AM
LavishLex
Suspension and Brakes
10-01-07 09:16 PM
Mixman
05-19-06 11:20 AM
Quick Reply: Best Springs For '06 Gs300 Awd ?
