questions about tanabe nf210?
i'm thinking about getting the tanabe springs, but i have couple questions. What shocks do you guys use? Can the stock shocks handle the pressure? i had the espelir springs on my previous gs before and the stock shocks didn't hold to well, im afraid the same will happen if i use the tanabe and stock shocks together. anyone have problems with this comination? also just wondering when is the tein cs coming out?
Stocks, unless you opt to go with the Tein SS Coilovers. Then you get the entire setup (minus upper mount on the SS)
From my conversations with Tein, there is no exact ETA on the CS kit. Soonest would be end of summer on completion of product, which means we won't have them until probably the end of the year... I'm waiting too.... Better start calling dibs on my SS-kit!
Originally Posted by slimj 281
how does the tein ss ride? are you switching springs because it rides too rough? i had the teins ss on my previous car which was an integra and i didn't like it much it rode kinda rough, wondering if its the same on the gs.
I still haven't had the time to tune the dampening as of yet so it's very retarded right now... All the way soft in rear and all the way hard in front... (i'm so lazy....)
The Tanabe NF210 springs are designed to have a spring rate that is only a very small percentage higher than stock, so the factory shocks will be able to function properly and dampen the spring properly without issue. The NF210 is the most ideal for factory dampers.
Our DF210 springs have a higher spring rate that is roughly 10-15% over stock, and an aftermarket damper may be better suited for that line for long term useage, although we have not had any reports of any damper failures as the vehicle and spring are still only about 1 year old.
It's always best to check the product information on springs to see how much stiffer the spring is over stock. Extremely high rate springs typically require an aftermarket shock to function properly. In some cases, there are no aftermarket dampers available for the vehicle, so please check beforehand!
Guest
Posts: n/a
Originally Posted by 1SICKLEX
Thank you so much for this information
The better informed everyone is, the happier they'll be with what they chose!
jentlemaan
01-08-08 05:55 PM
Rich27
Suspension and Brakes
05-01-04 09:50 PM
