question on tein cst
Trouble Maker
I thought it did too, until i opened the box.. Only the fronts come with the upper pillow mounts. The rears you'll need to use your oem ones.. i find it stupid, b/c the last set of TEIN CS on my 2GS both front and rear comes with the mounts. I guess Tein is cutting cost on the 3GS ones.
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
I thought it did too, until i opened the box.. Only the fronts come with the upper pillow mounts. The rears you'll need to use your oem ones.. i find it stupid, b/c the last set of TEIN CS on my 2GS both front and rear comes with the mounts. I guess Tein is cutting cost on the 3GS ones. ![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
yup, here you go andrew ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
https://www.clublexus.com/forums/sho...08#post3195708
will be installing it soon, if i miss any parts i will be running after you!!!!
sincityIS
Suspension and Brakes
12-05-07 08:29 PM
