Anyone rocking the Tanabe Seven coilovers?
I am currently looking at the % and the & with the TEAS system for adjusting the shocks from the drivers seat. I am tempted to go with the 7 bec of the higher spring rates, but I dont want to go over the edge and ruin the ride quality totally and start denting wheels bec the high spring rates stiff shocks and rubberband profile tires. I will probably go with the % with the TEAS and save the 500 bucks for an autocouture lip. Tanabe make solid products . I am sure the system is top notch. Even with the higher rates of the 7 you might just get the TEAS and leave the setting to soft.
I've heard most people go with the fives because of the softer spring rate. But aren't the sevens a fully threaded coilover. Ride comfort has to be better as far as fine tuning it. since they offer a hard drive kit i'm sure you can get the opposite of that and get some softer spring rate springs. Does anyone actually have these on their car?
the shocks can go softer but with the included springs the ride will be stiff. more of a performnce setup then comfort.
if going with the sevens get lower spring rates in the 8-7kg range to give a smoother ride. these rates are even lighter then the fives but heavier then the tien CS-T.
the full threaded body has pros and cons. pros it allows fine tuning and wider range of adjustment. cons is if you don't know how to adjust it you won't benefit from it and also wider gap of error in the lowering of the vehicle. in other words more bells and whistles.
now the main thing to ask yourself is, is the extra $500 worth spending for the threaded body and stiff spring where it could be used for getting the teas and lower spring rates for the five? because both already offers adjustments to shocks anyways.
the only real benefits to getting sevens is if tracking the gs and corner weighting the car. or if the sevens had an aluminim body saving weight.
I think I am going to save the money and go with the pro 5. What I am after is lower ride height with adjustable feature bec I am tired of the right side of the car being slightly higher than the left side, and I am desperately looking to MASSIVELY improve cornering ability. This car leans / rolls like a staggering drunk under hard cornering. What I want ti know is if I really need the TEAS.
lexus310
25
10-25-10 07:50 PM
TwentyTen
Suspension and Brakes
08-08-07 12:50 PM
