View Poll Results: Which one to get
Tein CS
![](https://www.clublexus.com/forums/images/polls/bar2-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar2.gif)
![](https://www.clublexus.com/forums/images/polls/bar2-r.gif)
![](https://www.clublexus.com/forums/clear.gif)
40.74%
JIC Magic
![](https://www.clublexus.com/forums/images/polls/bar3-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar3.gif)
![](https://www.clublexus.com/forums/images/polls/bar3-r.gif)
29.63%
Tanabe Pro 5
![](https://www.clublexus.com/forums/images/polls/bar4-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar4.gif)
![](https://www.clublexus.com/forums/images/polls/bar4-r.gif)
22.22%
Tanabe Pro 7
![](https://www.clublexus.com/forums/images/polls/bar5-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar5.gif)
![](https://www.clublexus.com/forums/images/polls/bar5-r.gif)
7.41%
Voters: 27. You may not vote on this poll
Choice between Tein CS, JIC Magic, and Tanabe pro 5 / pro 7 coilovers
Just checking out suspension options for the 3gs on l tuned. JIC magic has a set up that runs a few 100 dollars more than the loved tein cs. It has spring rates that are way higher than the tein cs, but it boasts the largest drop. And bec it has the adjustable shell case length you can slo keep full suspension stroke while the car is rolling dumped. any feed back or opinions would be appreciated
In AZ its already 115 deg and its not even july/aug yet. So it is important to check the pressures when they are hot to see if they are to close to max tire pressure. The guys at the wheel and tire place it reduces the chance of denting wheels and it will allow better wear since the car is dropped. all the place I went to said that min of 42 psi with a 30 profile tire. The highest I have ever seen was 123 deg 200 miles out side of phoenix. Out here the tire pressures when burning hot are important bec of the kind of temps we see. If the air temp is 123 deg what do you think the ground temp is? HOT AS HELL
I was looking into coilovers. I called a couple of shops in town and they all say they highly rec the tein over the tanabe. I wanted to know what you guys think of the set up. any prob;ems? Also I noticed that most members who are running this set up have the car dumped usually to 2+ inches drop and say the ride quality is great. I know that the tanabe pro 7 allows the case length of the shock to be adjusted to maintain a higher amount of suspension stroke, so I can imagine that the ride is pretty good while the car is dropped. the tein cs on the other hand doesnt have the adjustable case length, but says the height is adjustable via a spring perch aand thredded shock body. I am wondering if the threaded shock body allow the set up to maintain full stroke at low ride heights. Both systems run almost the same price so I am game for either. In the end the tein cs has spring rates that are close to double that of the h techs I have now. The tananbe spring rates are almost triple what I have now. I dont want to ruin ride quality but I want full stroke while lowered. I know thw Tanabe pro 7 and JIC FLT VIP coilovers allow for adjustable case length for better ride and stroke length while slammed, but the tein CS seems like the forum/industry standard
I dont know if the tein cs has the feature of the adjustable case length. It would be big time if I could drop the car 1.5 to 2 inches with a somewhat decent ride. what trips me out about the jIC magic set up is the 13kg spring rate for the front. DAMN that is really high
ability to adjust height and keep the travel can be a bad thing imho. when you lower the car, travel should be less, otherwise after certain point you risk bottoming out your car too easily. bad idea.
when i had flex on my gs400, it allows lowering and keep the same shock travel. i ended up not using that feature at all
You know I have the Tein Super Streets... They are awesome... car is super slammed.... and rides great even with the 25 series tires.... stiff but smooth at the same time... dont know if that makes sense... imagine a BMW with Lexus quite....
In all honesty....just make a poll on what people have and go with the crowd. If pricing isn't a concern there is better, and if pricing is a concern get the cheapest.
All low lvl coilovers (Tien CS, Tien SS, Tanabe Pro 5, and Tanabe Pro 7) all use KYB shocks. In other words it's all based on the spring rate for each company to make the differences. If you want the best setup and the best ride quality I suggest going with Tien and ordering a custom valved setup and custom spring rate, or get KW's or something.
Both the Tanabe Five and Seven use the same rear spring...just an FYI.
1. you want the most travel - not a good idea...if you hit a speed bump you are going to botom out your frame on the speed bump if you are that low.
2. you want handling - will compromise the ride for better handling
3. you want ride comfort - will compromise the handling
4. You want the valve controller - expect to pay close to $2k with the Tien CS including the valve controller
Tanabe Pro 5 will run you in the ball park of the coilovers of the CS and it's including the TEAS. Meaning it's cheaper.
Spring rate from 7-9kg doesn't feel that much of a difference because
1. the car weight close to 2 tons
2. our cars don't weight 1 ton where the spring rate makes a huge difference
3. as long as the dampening of the shocks go along with the spring rate it'll feel smooth, if not it'll be jarry or harsh on rough roads or feel like a boat(not enough dampening)
My suggestion is if you plan to only go 1-1.5" lower any of the coilovers will be fine and work. The dampening will be adjustable and any of the coilovers should feel good enough.
Another option I highly suggest is go on a test drive with a local Lexus owner with the suspension in question and feel for yourself. If not you will just complain on the ride. Everybody has different tastes, and feel on what they like and what is acceptable. Running 10kg front and 8kg rear on a 2k lbs car can be acceptable for some for the handling they desire but not acceptable to others. A very good read I saw was of the comparison of the SS/CS/HA setup by a fellow Lexus owner.
on my last note, have you looking into finding if the springs in question are linear or not. If a spring is rated 7kg and not linear it can feel 10kg when it's fully compressed versus a linear 8kg spring which make it feel softer at full compression.
