what springs are stiffer than the tein h tech..
i had the tein h tech spring on my car and i wanna know if it would be better to go off with stiffer springs. would it make a difference if i go with stiffer springs since i am on 22s because on the tein would bounce when i hit a dip. which company might make stiffer springs that are good for the gs350 awd
The TeinH are the least drop out there. So if you cant drop the car more then that I dont think you have to many options.
Can you shave or roll the fenders? are you sure the negative camber difference with the lower springs, Tein S IMO, wouldnt work or compensate? Reason I mention is another member took my rims and and put them on his 2gen IS and his car rubbed where mine didnt. He has Eibach springs and I had the Tein S springs. So the slight extra negative camber on my car made a difference. Hope that makes sense.
The next step from here is to get some TeinCS coils and slam that bad boy
yeah i have awd well the tein h tech are good, just the streets here in ny are messed up so i hit a dip and my car rubbed. normally i would not rub. i did a a lot of modification to the car for those 22s to be clear. thats the the suggestions though.
will i rub if i put h&r springs on 22s. the h&r are stiffer than the tein h techs. my tein h techs were perfect but when i hit a dip they weren't stiff enough. what do you guys think ?
dont forget you will get more negative camber as you go lower so it will allow for more room
I had TeinS techs on my last Lexus and the rims worked with no troubles. The new member they rubbed and it was due to not being as low as I was on a similar drop spring as yours. I say get the springs and make it work
h&r springs or have tein work on coilovers for me haha ? i think i might just go with the h&r springs. i am worried about it being a wayy to aggressive drop :/
