Suspension Springs, shocks, coilovers, sways, braces, etc.
finally installed springs for AWD..
Old 10-20-08, 02:15 PM
MKIV98TT
MKIV98TT's Avatar
B.Diddy, is your GS350 AWD?
Old 10-20-08, 03:30 PM
kyang91
kyang91's Avatar
It is kind of weird because i am running the Tanabe, and I do not have any of the kind of problem. The car just ride like stock and handles better then ever....
Old 10-20-08, 03:33 PM
retrospexo
retrospexo's Avatar
yo b. did the shop align the wheels when the installation was complete? i read in another thread posted by nardeezy that the shop he went to did the alignment as well.
just wanted to know if it's something that's mandatory on their part or something extra (but necessary) on ours.
Old 10-20-08, 05:46 PM
stvincent
stvincent's Avatar
B. Diddy..
didn't you have the same issue while ago?
Old 10-20-08, 08:18 PM
nardeezy
nardeezy's Avatar
Originally Posted by stvincent
Same width wheels/tires all around?
Old 10-20-08, 08:43 PM
stvincent
stvincent's Avatar
yeah.. 8.5, 245/35/20..
Old 10-21-08, 08:29 PM
B.Diddy
Lexotic Concepts
B.Diddy's Avatar
I had a clunking issue.... I did my own install... I reseated the Rubber spring insulators and applied a little lithium grease to them to allow them to move and not bind if needed. I did not do an alignment.
I had vibrations at first, but that was when it was cold outside. I had a vibration hard enough to lightly jiggle coins in the coin holder. Since weather has been warm.... no vibrations. no nothing.
Weather is getting colder here and I will see if the early morning vibrations in Reverse return. I bet it has to do with cold weather tranny operating temp more than anything.
I have a 2007 GS350 AWD.
Old 01-15-09, 11:49 AM
jjpxlala
jjpxlala's Avatar
I have gs350 awd (2007) and I had this problem since I changed it to NF210.
Vibration when in drive/vibration drive slow/etc...
I did the alignment and I took my Iforged wheel and put stock wheel back on and still have problems.
At winter time when weather is cold I gets worse. I took it to dealer 3-4times and they couldnt find out what the problem was...
I dont know what else to do? change it back to stock?
anyone fixed this problem? anyone?
Old 01-15-09, 06:52 PM
stvincent
stvincent's Avatar
like *MKIV98TT* mentioned, i don't think there's a cure unless you go back to stock. i went back to the installer, they checked to see if anything is wrong, but they couldn't figure out the problem either. the shop did mention something about the position of halfshaft or driveshaft.. i'm kinda getting used to vibration though. i rather keep this look than going back to stock..
Old 01-15-09, 09:01 PM
vietdeluxx
vietdeluxx's Avatar
...i'm kinda getting used to vibration though. i rather keep this look than going back to stock..
Ahhh.. I see the mod bug bit you too... too late to go back to stock now.
Old 01-19-09, 04:34 PM
jre002
jre002's Avatar
Originally Posted by whlkev
lowering & AWD are kinda like oxymoron
Don't know about that... plenty of AWD sport cars and sedans.
Old 01-19-09, 08:59 PM
gs350on22s
gs350on22s's Avatar
i am in the same position right now. i am having a vibration when i put my car in gear and when driving on the highway. i got pissed off last time and paid to put my stocks back on and a week later i was like no way and put my teins back on. i don't know what to do with this vibration. if i only knew when i bought the car i would of got rwd but now its to late. there has to be something already...
Old 01-19-09, 09:11 PM
SNiiP3R
SNiiP3R's Avatar
hmmm I still dont get how springs can cause vibration....Anyways, have you guys tried other brands? Tanabe NF / DF springs ?
Old 01-20-09, 03:40 AM
IXI187IXI
IXI187IXI's Avatar
its pretty much like someone said in this thread. it all depends on the positioning of the half shaft once its lowered. once it goes past a flat horizontal point is when you get the vibrations.
Old 01-20-09, 08:36 AM
spine911
spine911's Avatar
It is apparent that once you go back to the stock spring/height, the vibration ceases.
Im wondering if anyone with AWD lowered with Coilovers tried comparing settings. Does the vibration improve with higher setting?, or worse with the lowest???.
STVincent,
What is your current Tein Coilover setting? Have you tried changing the height setting, and comparing if the vibration changes?
Quick Reply: finally installed springs for AWD..
