Suspension Springs, shocks, coilovers, sways, braces, etc.
GS AWD (lowered suspension data)
Old 04-15-10, 01:35 AM
  #151
chapagetti
chapagetti's Avatar
Seems to me the vibrations could only be coming from one thing.. the engine. when it's colder it vibrates more due to a higher idle correct? the softer mounts would probaby help but who makes them? and the lower the car is the stiffer the suspension therefore the vibrations also increase. One question I have is, is it possible to have a tein coilover setup with edfc on an AWD? Seems to me everyone is pretty much using a RWD suspension setup anyway.. I saw they make tein coil +edfc for 06+ gs300 rwd. I'm wondering if loosening up on the edfc will effect the vibrating, if so how much? Also, I was thinking doing something with the CV joints like getting custom made ones that will possibly absorb some of the vibrations just like the hypothetical mount idea would work.. sorry I'm a newb on this forum and not a mechanic but just read through all 10 pages of posts and throwing some ideas out there.. I would love to lower my gs350 awd but do not like the idea of crazy vibrating.. I'd rather have that on my EK hatch. I hate the stock height but I think if my car is vibrating like crazy all the time it kinda defeats the purpose of owning a Lexus.. that's just me tho. hopefully we can figure out a solution to this problem because it is definately MAJOR.
chapagetti is offline
Old 04-15-10, 11:02 AM
  #152
anaq110
anaq110's Avatar
Default F-Sport on 2007 GS350 AWD
Hey Guys,
Just got my F-Sport springs installed and drove up from Jersey to Toronto. I can't begin to state how happy I am. My intension of drop was for improved looks like everybody else but I was so shocked at handling. The car was hugging the corners of I81 and riding like a true Lex should.
No vibration\wobbling issues at all in fact I think the slight vibrations I had prior are gone also. I pushed up to about 100mph and didn't feel a single thing. City driving was good also. I will post up pictures later with before and after.
Other work I had done was get Lexus OEM rotors and Akebono pads all around.
Special Thanks to Yang1815 n others for giving me the confidence to pull the trigger and Riteway in Jersey for wanting to do the work.
Clublexus rocks and I have learned so much here from so many knowledgeable members. I wish I was more active when I had my GS400.
Next Step- 19s or 20s Stag vs Non Stag TSW vs Vosson
anaq110 is offline
Old 04-19-10, 06:13 AM
  #153
IXI187IXI
IXI187IXI's Avatar
i dont think it is the engine for the fact the vibrations occur all the time whether its cold or not. also the vibrations do not increase or decrease unless you lower/raise the car. the lower the car goes the worse it gets. dampening would have nothing to do with it. if i set my dampening to 30 the vibrations will still be there and visa versa.
IXI187IXI is offline
Old 04-20-10, 12:45 PM
  #154
ryan78
ryan78's Avatar
since we are pretty sure that the vibrations are caused by axle angle, has anyone thought of using a drop spindle to correct? can such a thing be fabricated or is there one in existence that can be used? just a thought....
ryan78 is offline
Old 04-21-10, 04:43 AM
  #155
IXI187IXI
IXI187IXI's Avatar
it would have to be custom made. maybe i can talk to my buddy to see if something can be done. he owns an airbag and hydraulics shop. there has to be something that could be custom fabbed.
Old 04-21-10, 06:10 AM
  #156
ryan78
ryan78's Avatar
keep us posted. i would imagine anything to lessen the axle angle would help. of course, raising the car up is not an option. LOL.
ryan78 is offline
Old 04-21-10, 11:11 AM
  #157
riles200
riles200's Avatar
If it is the angle of the axel, then why when you put the car in neutral at a stop, the vibrations disappear? Could it possibly have something to do with the drive train for the front wheels?
riles200 is offline
Old 04-21-10, 11:40 AM
  #158
ryan78
ryan78's Avatar
i would guess because there is no load on the drivetrain with it in neutral?
ryan78 is offline
Old 04-22-10, 10:38 PM
  #159
Kcook700
Kcook700's Avatar
08 AWD 350, looking to lower a bit, I can't stand this 4x4 look. Few questions for everyone, does anyone know if the NF210's are the same for RWD and AWD? Second, NF210's vs. F-Sport, how do they actually compare drop wise and comfort.
Kcook700 is offline
Old 04-29-10, 09:39 PM
  #160
chapagetti
chapagetti's Avatar
ok guys, I went into Lexus today and inquired about lowering my 07 awd gs350. they told me they have an F-sport lowering spring set for awd now. they quoted me $800 and some change. can anyone verify? this is big news for us if it's true. I would imagine anything they manufacture from F-sport will not cause any vibrations...
Old 04-30-10, 05:04 AM
  #161
IXI187IXI
IXI187IXI's Avatar
there is no difference in the springs. you can use the rwd springs and be fine. there are several members using the rwd springs with no vibrations.
Old 05-05-10, 09:43 AM
  #162
RudeDoggy
RudeDoggy's Avatar
While that may be true, this member has vibrations with F Sport springs.
I get an unexplained vibration in the steering wheel (a slight shimmy, like the wheels are not balanced, as well as a high frequency vibration feeling) when hammering on the gas (e.g. 4000 rpm+). I have yet to figure out the problem.
RudeDoggy is offline
Old 05-05-10, 09:51 AM
  #163
IXI187IXI
IXI187IXI's Avatar
hmmm interesting. most of the members ive seen using the F sport springs had no issues. then again this whole vibration thing is subjected to personal opinion.
Old 05-08-10, 01:26 PM
  #164
chapagetti
chapagetti's Avatar
so I'm assuming you're using RWD springs on an AWD correct? then it goes back to my question.. did f-sport release an awd spring set? I don't think lexus would install rwd springs on an awd car, at least the one by my house won't. plus if F-sport is putting out an awd spring set that Lexus dealers will install I don't see how it can cause vibrations.. am I right?
Old 05-11-10, 04:38 AM
  #165
IXI187IXI
IXI187IXI's Avatar
as far as i know, no there are no awd fsport springs. there is no difference in springs. the only thing different from the rwd suspension to the awd suspension is the awd bracket attached to the bottom of the front struts.
even people with the road magnet awd springs have reported vibrations.
Quick Reply: GS AWD (lowered suspension data)
