Suspension Springs, shocks, coilovers, sways, braces, etc.
GS AWD (lowered suspension data)
Old 05-11-10, 08:30 AM
  #166
IK828
IK828's Avatar
I came across this thread, which seems kind of old...
https://www.clublexus.com/forums/gs-...r-and-d-3.html
Has there been any updates with this? I want to lower my vehicle and I am considering some NF210's or Fsport springs for my AWD
IK828 is offline
Old 05-15-10, 09:26 AM
  #167
SU7R3M3
SU7R3M3's Avatar
07 3GS AWD - Installed FSport springs almost a week ago, have some increased vibration at idle and in gear, and a small wobble during initial acceleration. Honestly had I not read this thread I likely wouldnt have picked up on it so easily, and its minor enough that it doesnt bother me. Love the drop and ride quality, pot holes are definitely more noticeable now but on the highway its very smooth and handles much better. Plus that monster truck gap is now gone, overall, very happy with the springs and hope I dont have too much gap when I put on staggered 20's in the next couple of weeks.
-Edit* The vibration and slight wobble were there on stock springs, vibration increased a bit after the springs, wobble increased very little to where I barely notice it. Keep in mind Im coming from a slammed Infiniti M that was off alignment and wobbled all over the place, plus before that an evo with a hardened motor mount on coilovers, so my perception of it is much more forgiving.
SU7R3M3 is offline
Old 05-18-10, 08:18 AM
  #168
IXI187IXI
IXI187IXI's Avatar
so on my never ending quest to find a solution to this, i took my problems to the wrx/sti forums since they are also awd people. i think i may have stumbled apon something that may help us.
Over on S2ki people have vibration issues with the S2000.
The car's suspension is highly tuned so lowering the car over ~1 inch may cause a friction point between the inside of the CV bucket and roller bearings.
Driveshaft spacers solve this.
as i continue my research i will keep everyone informed.
IXI187IXI is offline
Old 05-18-10, 08:26 AM
  #169
ryan78
ryan78's Avatar
this would be fantastic!
ryan78 is offline
Old 05-18-10, 08:30 AM
  #170
IXI187IXI
IXI187IXI's Avatar
it would be and im sure we have enough of a demand that we could probably get these made.
Old 05-18-10, 09:02 AM
  #171
ryan78
ryan78's Avatar
damn skippy!
ryan78 is offline
Old 05-18-10, 09:52 AM
  #172
IXI187IXI
IXI187IXI's Avatar
im going to work on contacting a local performance shop near me that does all there own machine work. im sure they would be able to machine up some spacers.
Old 05-19-10, 09:02 AM
  #173
IXI187IXI
IXI187IXI's Avatar
heres some information if anyone wants to read about the vibrations
Cause of vibrations
Old 05-19-10, 09:44 AM
  #174
telmz1
telmz1's Avatar
i'm praying this is the solution to our AWD problems so I don't have to get rid of the car.
telmz1 is offline
Old 05-19-10, 09:47 AM
  #175
IXI187IXI
IXI187IXI's Avatar
im working on it. ill keep everyone updated.
Old 05-19-10, 09:51 AM
  #176
ryan78
ryan78's Avatar
thanks!!!!
[edit]
mmkay. just finished reading the link that 187 provided. very informative, as were the links that were provided from the s2k thread. this led me to call my mechanic, to see what he thought of the idea that wear placement in the cv bucket could have more to do with our vibrations than the acutal axle angle, given how placement would change with lowering. he agreed that this could definitely be the cause.
now, i will be changing my cv boots sometime 'soon' as they have been leaking for 30k or so. he explained to me, given labor costs for the job (3hours or so), he recommended just changing out the whole axle assembly (cv basket, boot, and axle [hour or so]) as a more cost effective solution given i wanted new cv baskets as well. a rough quote of 'less than $600' was given. i probably will have a friend who is an ASC certified master toyota mech do this on the side to save a bit of $$. if we were to get the spacers, it seems like costs will be between 150 and 200 plus installation. for an extra hundred or two, i get new axles, boots, and baskets. seems like the way to go for my particular situation. just figured i would put it out there for those that may be in a similar situation regarding leaking boots. any thoughts to this being a viable solution? thanks
ryan78 is offline
Old 05-19-10, 11:39 AM
  #177
IXI187IXI
IXI187IXI's Avatar
for lowering springs i see that as a solution since the "spyder" would retain in the same spot. obviously as you raise and lower the car, the positioning of the spyder changes. I think new cv axles will fix the problem if you leave the car at one height and never touch it again. If you raise or lower the car after putting in the new axles, you will eventually end up with the problem again imo.
Old 05-19-10, 12:39 PM
  #178
ryan78
ryan78's Avatar
agreed, any change in the suspension once the 'break in wear' has happened will result in the same issue. again, since in my case the recommendation is to replace the whole axle assembly instead of just the leaking cv boot from a cost standpoint, it's a win win situation for me. may not be the case for others. just glad you found that thread! 600 bones to have a vibration free car would be well worth it imo. i think the ride on the BC's will be quite nice with the vibrations eliminated.
ryan78 is offline
Old 05-19-10, 12:48 PM
  #179
IXI187IXI
IXI187IXI's Avatar
just dont change the height of your car and you should be good!
i on the other hand like changing my height so im holding out for the spacers.
Old 05-19-10, 01:28 PM
  #180
ryan78
ryan78's Avatar
lol. yeah, i understand that. only way that will happen for me is if i go to air. which means i need another DD. which means that the GS will sit. which means a ton more mods and $$$ out the window. lol.
ryan78 is offline
Quick Reply: GS AWD (lowered suspension data)
