GS AWD (lowered suspension data)
18 out of 20 AWD Owners are Lowered
2007+ GS350 AWD
retrospexo – road magnet; no issues reported
B Diddy – eibach pro kit; no issues reported (staggered 19's)
stvincent – tein s.tech; typical AWD vibe and low speed vibe (20's all around)
Kyang91 – tanabe nf210 no issues reported
MKIV98TT – tanabe nf210; typical AWD vibe's
kuch123 – tanabe nf210; no issues reported
sbrown02 – tanabe nf210; no issues reported
spider 55 – tanabe nf210; typical AWD vibes (19's all around and stock 17's for winter)
gs350on22s – tein h.tech; reports of excessive vibration, problem is not yet isolated, pm for details (aftermarket 22's)
ICENUTZ – no issues reported (Staggered 20’s only, not lowered)
01a4man – tanabe nf210; not yet installed (staggered 20's)
2006 GS300 AWD
nardeezy – tanabe nf210; typical AWD vibe and low speed vibe (staggered iForged 20's)
Mixman - tanabe nf210; no issues reported (aftermarket 18's all around)
apok003 – tanabe nf210; typical AWD vibe and low speed vibe(staggered iForged 20's)
Jdog – no issues reported
Jai015 – tanabe nf210; AFS sensor (install issue)
Conclevage – tanabe nf210; no issues reported
planoag – no issues reported
SGT – tanabe nf210; no issues reported (Tourmaline 18's)
4thone – tanabe nf210; no issues reported (aftermarket 19's)
typical AWD vibe = idle at a stop light while in drive and brake applied (significant during cold startup)
low speed vibe = acceleration between 0/5mph - 15/20mph vibration (very subtle side to side)
Reply to this post if you are not on the list and want to be added (lowered or not).
added "01a4man" info.
2007+ GS350 AWD
2006 GS300 AWD
I have stock springs with 19" rays, however I noticed the vibrations before changing wheels, I'm not sure if these are the vibrations that are occurring with aftermarket springs or are people just noticing it after they replace springs.
Panning on going with either Tanabe NF210 or Eibach Kit.
18 out of 21 AWD Owners are Lowered
2007+ GS350 AWD
gs350on22s – tein h.tech removed; reports of excessive vibration, problem is not yet isolated, pm for details (aftermarket 22's)
2006 GS300 AWD
tripleJs15 – typical AWD vibe and possibly low speed vibe detected prior to installation of aftermarket wheels/tires (aftermarket 19’s only, not lowered)
Added tripleJs15 under GS300
2007+ GS350 AWD
2006 GS300 AWD
18 out of 22 AWD Owners are Lowered
2007+ GS350 AWD
mikedozz – n/a; no issues reported (aftermarket 20's, not lowered)
2006 GS300 AWD
Added mikedozz under GS350
2007+ GS350 AWD
2006 GS300 AWD
Correct. I have everything stock w/exception of 18" wheels off '06 GS430 w/factory Dunlop Run Flat tires. The vibration started for me after I took the car to a dealer for the courtesy 30-days check-up. I noticed the vibration while in Drive waiting at traffic lights. Lexus dealership said the new engines they began using in '06 models is different than previous "smooth as butter" engines I was accustomed while riding in older model GS & ES owned by friends of mine. I was told the vibration is a by-product of how the engine breaks in after the first couple of 1000 miles & that it was normal. Simply put, it is rough idle. Has nothing to do with suspension modifications, but perhaps the new springs or coilovers (geometry) magnifies the vibration, making it more noticeable.
Again, I noticed the rough idle year round (in VA/Wash DC area), but it the rough idle is less noticeable when I have the AC/Heat turned on or when in Auto mode. Apparently the load of heater or compressor for AC effects the load on the engine & transmission. When the AC is not on, the vibration is much more noticeable.
Sorry for the long note.
By the way, thanks to Nardeezy for pulling together this one-stop list. I decided to keep my '06 GS (lease expired mid-February), so I intend to lower my GS this summer...maintaining the factory '18 wheels for now. When the run flats wear out, I'll switch to conventional tires.
Question For All On This Thread. Last week I started noticing intermittent rough idle or shuttering of the car after breaking hard in stop & go traffic. As if the car is about to stall & cut off, but it doesn't. Only experienced it once this week, but several times last week during rush hour when I had to aggressive apply the brakes to avoid rear-ending someone. Got just 28,500 miles (yeah, I know low miles for '06).
Also, did anyone receive the Service Notices in the mail? I got three of them today to replace the fuel delivery pipes, another one to apply grease to the slide pin on the rear brake calipers, & a 3rd one to replace the electric power steering link assembly. Per the notices received from Toyota/Lexus, all three recalls apply to '06-'07 GS models
I had the rear afs sensor replaced and it seems to be fine now. I do feel that the car is sort of "bouncy"...
Evel - I experienced the same issue with my car (where it feels as if the car is going to stall). It's only happened about 2 -3 imes in the past couple of years and when I brought it in to Lexus to have it looked at - we couldn't recreate the problem. Btw, how do you get the recall notices from Lexus? Thanks.
The factory/safety recalls arrived from Lexus by mail last week. I will take the car into Lexus to have it serviced on Wed. If you have not received the notice & have a '06-07 GS model, you should receive it any day. If not , contact a local Lexus dealership for more info.
