F sport sway bar offical thread
#121
Lee
#123
don't worry about avs, seriously they shouldn't have anything to do with sway bars
the screw tightening thing was specially important back in my 2gs days. i had trd and then daizen and from my installer, a lot of times the tq on the screws are the "key" to noise. well, at least on the 2gs
#128
I know the specs for the F sport sway bars but not the stock set up. They do give the increase in stiffness on the web site. Its considerably stiffer/more resistant to rolling
#129
just had mine done installed at local shop for 40 bucks perfect! feeling is great cut corners much difference everyone should get it. its easy just let ur muffler cool down before doing it. basically got it lifted took out the old and put in the new exactly the same way. only hard part i saw was removing the engine case from the front.
#130
#131
Will anybody lives in OC and allow me to drive their car for 5 min with Fsway bar? i will pay him $20. seriously!! ^__^ . i know handling is day and night with sway bar. but just wan to actaully feel it. PM Me.
#132
yes! after couple days of hard corning! SWAYS MAKES THUMPING NOISE.. seems they r getting loose... imma go in and check to see if my mechanic was right about the screws on the links getting loose!! THUMPING NOISE! when going thru pumps or going thru dips side ways
#133
I wonder if its too much pressure on these tiny/weak end-links. We really need something aftermarket. I ordered new ones so I can report back if that helps out. Everyone I talked to said you should not reuse end-links so I have new ones on order with Darrel at Sewell.
#135
I have no issues. Maybe my service replaced the end links. I push the car but no very very hard. I dont know how hard you guys are pushing it
