Coilovers for AWD GS350?
#61
$125 is a good price. I paid $250 but I felt it was well worth it as they spent more time trying to get the drop right and even. I think they lifted the thing up and down about 10 times until they got it perfect. This guy wanted the measurements to be perfect down to the cm even after he test drove it.
I raised mine up about another inch which basically equates to a Tanabe NF210 or maybe Fsport drop and still have the vibrations between 10-20 mph. It annoys the hell out of me, especially in rush hour traffic. I find myself punching it when i take off so I can get to the 25 mph to bypass the vibrations.
However, the ride is a lot better than when I was on stock struts and DF210s. Bumps are no longer painful or shocking...and I'm not bouncing around like a civic.
Be sure to get the extenders from Tristan!
#64
IOCCA, I agree with you 100%! IMO, C-MS on behalf of BC Racing needs to be chiming in on this thread communicating an explanation on what's causing the vibration experienced by everyone at various levels & dampening settings; & the optimal setting they identified during development & testing that ELIMINATED vibration. For $1250-$1500 (whatever the cost + labor + alignment) you should expect a ride experience without vibration.
#65
BCR tested these out very thoroughly on the AWD GS they had, the slight vibrations they had initially went away after only driving the vehicle around for about a week. They also tested these out with a forum members (laobob) on an AWD IS, and he was slammed and he had no issues. So it is very odd and frustrating that some of you are having vibration issues and some aren't.
The problem obviously isn't with the coilovers themselves, but with the design of the stock suspension geometry and axles. It most likely has to do with the angle of the axles in relation to the suspension and the driveline itself. I am not sure if the rear needs to be level, lower, or high than the front to be ideal for the driveline angle.
If you are experiencing slight vibrations I would drive around for 1-3 weeks and see if it goes away after the suspension settles. If that doesn't do it then try raising the car up all around. Then try raising the rear more than the front, or vice-versa. Sometimes when installing aftermarket stuff on a unique vehicle a little trial and error needs to be done. Also check and make sure everything is 100% re-installed correctly and tight, and make sure the axles are seated properly, even a mm out of its socket and an axle can cause vibrations.
You also have to remember, aftermarket coilovers will result in a little more NVH. The stock suspension is pretty soft and has a hundred little rubber bushings in it which soak up vibrations, but also give you that floaty, disconnected feel. I think a little more noise, road feel, vibration is ok for a nice set of coilovers and a drop. But If you can't deal with a little more NVH and aren't satisfied we will do what we can to make you satisifed
#66
You also have to remember, aftermarket coilovers will result in a little more NVH. The stock suspension is pretty soft and has a hundred little rubber bushings in it which soak up vibrations, but also give you that floaty, disconnected feel. I think a little more noise, road feel, vibration is ok for a nice set of coilovers and a drop. But If you can't deal with a little more NVH and aren't satisfied we will do what we can to make you satisifed![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
#67
yes - i have those! i'm glad CM posted the above. i just put on my wheels last saturday - 20 x 8.5 and 20 x 10, and have vibration only at certain speeds when i let off of the gas only. conferring with my shop, we think that this is probably due to either engine mounts or axle vibration. given the issues everyone has been having and posting, one could...*** u me...that the issues lies in the axle angle. i will spend the day troubleshooting when we install to see what setup works best on my end and post; hopefully it will help those who install in the future. i would ask if anyone finds an optimal setup for their application to post so others can benefit. i am sure it will differ for each car, but it is always good to have a starting point. if CM could chime in on BC's behalf with what info they may have to help, that would be fantastic as well. many thanks to CM and BC for getting us AWD owners a product specifically designed for our cars. hopefully with our collective troubleshooting/experiences, we can elimintate the vibrations' concern that turned us away from RWD springs. thanks to everyone who has posted their instillation experiences to this point as well. good stuff.
#72
Ryan - So far I have posted what we know and what BCR has told us.
BCR didn't have to do much of any troubleshooting with the suspension and vibrations on the test GS AWD they had. The vibrations simply went away after less than a week of normal driving. They chalked it up to suspension settling, especially since the IS AWD's were having no issues.
When I personally went over to BCR and drove the GS for myself, it was a ssmooooth as could be.
Unfortunately sometimes small problems arise once a few people get them on and on the streets.
We are definitely here to help in any way we can. We will tell you what we know, and if it does come down to an ideal suspension setup, and somebody figures it out we will gladly post the figures.
#73
We are definitely here to help in any way we can. We will tell you what we know, and if it does come down to an ideal suspension setup, and somebody figures it out we will gladly post the figures.![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
For the record - these BC Coilovers did NOT cause the vibration issues that I am having. I had these when I had Tanabe DF210s. I had the car at stock height for like 3 days so I'm not sure if I had the vibrations then. The issues I am having (vibrations during 10-20 mph) seem to be hit or miss with the various GS and IS AWD cars out there. I don't have vibrations when driving at high speeds or letting go of the gas (unless its between 10-20 mph).
Other than the vibrations - these coilovers ride great! I was really suffering when I was on the DF210s.
Now if someone can educate me on the 'rebuilding' of these such as when to expect or what the symptoms are that its time to.
