Lowering Springs for GS460
Hi guys..
I just received the 20mm Ichiba spacers and will be installing them tomorrow. I want to pull the trigger on a set of springs immediately...
I don't want them too low, I dont want rubbing issues. I want them to sit slightly lower ( maybe an inch ) to compliment the wider stance.
Any ideas? Any vendors here can provide me these springs.
We don't have F-Sport here in Bahrain, i dont know if they make springs for the GS460. But I really need lowering springs now.
Thanks in advance.
PS: I am running OEM 18" Gunmetal wheels
Thanks in advance.
i had tien coilover on my gs460 n it ride smooth but if u gonna drop all the way down u gonna need to do some fender work but if u gonna go an inch or two lower u dont need spacer u be fine
No fender mods should be needed with stocks itself. I am sort of slammed on stocks right now (18" stocks) and no rubbing, even at a 1" drop there shouldn't be any rubbing. If your spacers are aggressive, then you might have rubbing. But from the amount of camber I see now with even a 2" drop, u can easily run a decent spacer.
Here you go guys!
20mm Ichiba spacers all around on stock springs and stock wheels.
I don't want my car slammed, and I don't intend to change wheels. It's my daily driver.. I just wanted a slightly more aggressive look to pronounce the car as a V8 the way it shouold be...
I need a ONE INCH drop all around... that's all.
i think the eibach springs have the drop you are looking for. also, tein makes a set that is close to that drop as well - i believe it's the s-tech. there are also the tanabe that were listed previously. the eibach are the most cost effective if i recall from my searches. good luck in your search.
