I've done some searching already and haven't found anything recent on these coilovers. Any more of you out there running these coilovers? If so, how do you like them?
Thanks. I have read that post in before but i'm hoping that after nearly two years, someone else has more experience they could share.
I purchased the Pro fives and installed 2 days ago. I am running Michelin (super square) 295/25-20 and 243/35-20. The suspension is all the way down on the rear and 5 turns up on the front. It is set on medium setting for dampening and it rides incredible. As for the wheels I am running 9" front and 10.5" rear. Only rubbing i have is front plastic where bumper support is located at about 3 oclock position (pass side). I was between the Megans, Tein and Tanabe and am extreemely happy with the Tanabe's.Good luck. I will post some pictures soon. BTW I did cut rear fenders and slight rol and tab odification on fronts.
Thanks Empani, for the feedback. Do you know how these ride in comparison to Tanabe DF210's (if you've ever ridden in a GS with them)? Also, do you have the TEAS?
I have the Pro Five going on 2 years now and its been fine. I first had it on medium for the first couple weeks but the ride was still too harsh for me so I set it soft. Its a lot closer to the factory ride at soft.
