Struts
Can anyone recommend some good quality struts..I keep hearing from people that if i change the springs then i should change the struts too..i have tein s tech springs.
as far as i know, fsport is the only one right now?
https://www.clublexus.com/forums/clu...available.html
when you get springs, it's always recommended to change shocks as well. this is because with lowering springs, you are putting more stress on stock shocks and thus wearing them out faster. a correctly paired shock set will avoid that
based off your location (NY) i would assume that you have an awd gs. if that is the case, f sport shocks/struts will not work as they are only made for the rwd gs. the rear suspension between the 2 are the same, its the awd bracket on the front struts that are different.
